straighttalk.com Logo
Anna Love Posted on Aug 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phone is dead how do I reload on line - straighttalk.com
Brian Friend
Level 2:
Sergeant:
  • Expert 132 Answers
  • Posted on Aug 28, 2016
Brian  Friend
Expert
Level 2:
Sergeant:
Answers
132
Questions
0
Helped
57318
Points
625
If you mean you are out of minutes then first you must purchase some minutes to reload the phone. You can do this online at many retailers like Amazon or Walmart.com. Once you have done that follow these steps
https://www.straighttalk.com/wps/wcm/connect/StraightTalk/Support/FAQs/Getting+Started/Adding+a+Service+Card
1helpful
After when i reset HP Mini 110-3735dx the system no more found it( an operating system wasn t found)
redux 1
NO OS STATED before the ***** of pc. W7 was new
is it w8, w8.1 or W10 (slammed )
F11 dead. got you.
that means (list)
the hdd is bad.
or
infected with virus (damaged F11 partitions recovery)
or
some one put a Microsoft disk (not HP)
and did a install not using HP media.
bam
I call it slammed.
http://pcdied.com/XP-sux-sg.html#slammed
if I boot that PC and it run under say
knoppix 7 perfectly , then the PC is ok
if the disk test passes, then the HDD is ok
and only the partition (HP restore) is damaged or missing on said HDD.
is it missing,did you look ? we use that same linux disk to LOOK... to see
the knoppix disk tests are here. under bad hdd.
http://pcdied.com/brick-dead.html
http://pcdied.com/brick-dead.html#Knoppix
the order is this, flow)
1: is the PC ok? battery ok, coin cell ok?
2: test PC with Knoppix 7
is pc ok?
3: test PC HDD with Knoppix disk tests.
looking at SMART data first, is now out of spare clusters and lots of dead clusters growing,
yes, bad hDD, or even its dead, then we run the full hDD test using Knoppix boot stick,
4: ok hdd seems ok, i look at the Hp recover partition. using same knoppix.
is it missing, or obviously damaged or files missing?
then it was slammed.
5: we then install fresh what ever OS you want.
how to do that and choices are many.
best is the HP media kit , to make it like new.
other use other ways and take days to find all the missing pieces, (humpty-dumptied)
I can do that latter my self ,done so 1000s of times.
(I go to HP and see what is there and get all these files)
the PC came with W7, if your PC was not w7 now
that means you slammed the PC, with W10.
you have yet to say what OS you ran before it died.
if w7 great, if w10, ouch..
https://support.hp.com/us-en/drivers/selfservice/hp-mini-110-3700-pc-series/5082187/model/5111936
if you have damaged F11,
install w7 any why you can, (most ways fail)
a real MS disk from MS actual will work to a POINT.
the MS disk will miss many HP drivers. and all apps
so go to the above link and get them all
warning HP only SUPPORTS W7 on this PC> period.
Remove dead co line
disconnect the line in system programming.
program*#1234, then 400 sp-phone , enter co line no.
then select disconnect and store.
Line one wont ring
Call a tech in, name change will not harm a line period.
REVIVE A DEAD SAMSUNG I8910
have you tried to attach to computer and use the phone app to see if it can reload os on the phone.
did anything take place that you believe might have caused this?
Hi my 3500 nokia is dead after upgrade
There are two possible problems. it is either you have the wrong software for your phone or you downloaded a virus. so get a certified engineer to reload the phone software. thanks
Help
jvm 507 means the operating system on your blackberry needs to be reloaded. there are several resources to walk you through the process of reloading. It involves using the Desktop Manager Software as well as the Client software for your specific Blackberry device. Could even be a newer version of client software. Just reload the software and it should work just fine.
1helpful
My nokia 6708 phone is dead
CHECK IN NOKIA PRIORTY SHOP GET ITS FLASH IC CHECKED AND GET THE SOFTWARE RELOAD DONE USE GOOD ANTI VIRUS, DONT USE IN DAMP AND WET PLACES HAVING MOISTURE / WET HANDS ,AVOID USE OF BLUETOOTH TRANSFER OF DATA FOROM UNRELIABLE SOURSE & NEVER TRY MOTOROLA PC SOFTWARE TO PAIR. HOPE THIS SOLVES UR QUERRY CHOW! [email protected]
One line doesn't work at all
Line a line is dead? At the system you will see a port labeled line 1 and a port labeled line 2. swap them. That will prove if the line is dead or if the port of the system is dead.
Top straighttalk.com Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a straighttalk.com Computer and Internet Expert? Answer questions, earn points and help others
