Garden Logo
Robert Cook Posted on Aug 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My mtd gold will not move it is a hydro and wont tram eather way
L Pfaff
Level 3:
Top Expert:
  • Mtd Master 11,573 Answers
  • Posted on Aug 28, 2016
L Pfaff
Mtd Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587762
Points
181713
Robert, check the hydro. release lever at rear of tractor, if you can push tractor the lever is in release mode and has to be switched to engage mode. If this is not the problem it could be numerous things, broken/stretched belt, fuse for clutch blown,faulty clutch, park brake stuck on, broken shear key in transaxle or damaged, gear linkage loose, if any sign of hyd. oil leak check level/fill and bleed as per your manual,etc. You may want a good small engine tech. to have a look, diagnose and estimate repair.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Owners Center
Video Troubleshooting Tractor that Won Move
Lawn Tractor will not move forward or backwards ShopYourWay
http://support.mtdproducts.com/app/answers/detail/a_id/97/related/1/session/L2F2LzEvdGltZS8xNDcyMzk0MzQ2L3NpZC8yb3hyUmNabQ%3D%3D
2005 SUZUKI C50 BOULEVARD 800 TRAM TRIKE. How to adjust brakes on 2005 Boulevard Trike please?
Question edited for clarity.
Question moved to base model category.
That is difficult, because basically, you have bought a custom bike. Normally adjusting hydraulic brakes comes in 3 parts.
Make sure there is material on the brake pads.
Make sure free play is taken up if they have an adjuster.
Make sure there is no air in the system.
There is some generic help in the link.
https://www.google.com/search?q=2005+Boulevard+adjust+rear+hydraulic+brakes
'TRAM' Trike is unknown unless you meant 'Tram*'? (with a P)
I see Fixya Profanity Filter doesn't like that 'T' word!
Please always proof read before pressing 'Post Question'. Sometimes you need to be creative:>D
https://www.google.com/search?q=2005+Boulevard+TRAM+Trike
1helpful
Heal lever won't press down to engage transmission on hydrostatic transmission
Hydrostatic Drive Problems?? - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
May 30, 2006 - Hydro-Gear Transaxle:218-3010L I got this tractor as part of the deal when I ... After spraying the heck out of it and pressing the brake pedal down several ... I pull on the handle in the back and it moves the lever but still won't move. ..... while in the air and turning the wheels with the transmission engaged? mtd lawn tractor wont pull hills
Oct 18, 2009
briggs trouble
Jul 5, 2008
Peerless transaxle repair, Husqvarna mower
Oct 13, 2006
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Missing: heal
HYDROSTATIC TRANSMISSIONS - Small Engine Information
smallengineinformation.com/?page_id=370
Jan 14, 2016 • Garden
Troubleshoot toro ridinglawn mower starts but refuses to move
If it is hydro-static check to see if the transmission is disengaged it should be located on the back of the mower.
Jul 16, 2013 • Mtd Garden
Wont start gas
squirt some starting fluid in the carb see if it will startif not chek for spark at plug if fireing check gas for water after that remove float bowl from carb clean it out replace plug and it should start
How much oil do I put in my Mtd Gold self propelled mower
most push mowers are about a half a quart
May 11, 2012 • Mtd Garden
My riding mower start but it wont move
Is it a Hydro, or belt drive?
Is Hydro on bypass?
Is the belt off, or broken?
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 • Mtd Garden
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
