SOURCE: Wont work
Your door lock is not fitting correctly!
This is a safety override to make sure that the washer does not fill with water & leak all over the floor because the door is not locked properly!
Suggest you get the door lock mechanism checked out and adjusted. It could be that this has either become blocked with soap powder or cotton material shedded from your clothing over time.
The latch is normally available as a spare part, so you could check this out with your local Simpson dealer, or buy it on the internet once you know the part ref number.
SOURCE: Simpson Eziloader frontload washer clunks 3 times and ends
The motor controller or ECU is to blame.
Have them checked & replace as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: Simpson Front Loader won't start - Clicking Noise
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
SOURCE: I would please like a
A 5.5kg capacity front load washer with a stainless steel spinbowl, 8 wash programs, variable spin speeds, 2.5 star energy rating and a WELS 4 star water efficiency rating (56 litres). General Specifications Colour: white Overall Dimensions (Check installation guides in downloads for exact dimensions) Overall Height: 850 mm Overall Width: 600 mm Overall Depth: 630 mm Key Specifications and Features Capacity: 5.5 kg Energy star rating on old scale: 2.5 stars Spin Bowl: Stainless steel Wash Programs: 8 Water efficiency star rating (WELS): 4 WELS Water consumption: 56 Litres Other Specifications Door opening - Large: 300 mm Door opening angle: 165 degrees EAN: 8853328005026 Variable spin speeds: 800,650,500 rpm Other Features Colours 40/ Colours cold: Yes Cotton 60 / Cotton 60 eco / Cotton cold: Yes Cycle start/pause button: Yes Delicates 30 / Delicates cold: Yes Extra rinse: Yes EZILoader: Large EZILoader doors makes loading and unloading your washing easy. Levelling legs: The levelling legs may be adjusted if the floor is not level, to ensure correct operation of the washing machine Pre-wash: Yes Pushbutton electronic options: Yes Quick Wash: Yes Rinse/ Drain / Spin: Yes Rotary Electronic Controls: Yes Wool 30: Yes Warranty Details 2 years from the date of first purchase (3 months for commercial applications) and subject to the conditions set out in the warranty card accompanying the product when purchased.
SOURCE: I need a user manual
Google the make and model and add the words user manual to the end. There you will see numerous sites that offer either free or inexpensive user manuals that you can order or download. My favorite site is simply manuals.com.
