SOURCE: f 21 flashes
We have the exact same washing machine, and the same problem. we will need to lift the front of your washer up and undo the bolts to the front cover. you will see a white round turn nob, this is the filter unscrew it (you kight plug your nose) and empty all contents, replace, screw the front plate back on and you are good to go!
SOURCE: FIsher and Paykel washing machine won't stop beeping.
if you remove the back panel you can look under there, there should be atrouble shooter/techsheet that will let you know what the flashinglights mean. if not theres a tech support number to aid you as well
SOURCE: I have a siemens WM14S794GB washing machine and F23 is flashing
F:23 means that your machine is leaking and should be repaired. This is often a bad seal and if you are competent or know a friend who is they can inspect the source of the leak for you. Needless to say you should make sure that you unplug your machine before attempting any repairs.
Hope this helps you.
SOURCE: OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
