This Epson Printer error E-01 occurs in the Epson Service Manual which indicates a type of fatal error. It simply signifies that the printer is incapable to finish the self-test process. When users are trying to power ON the printer it begins to check for all systems. If it is found that it is unable to finish the self test process then, the printer will come up with an error message as mentioned above. Follow these steps to resolve Error E-01.
Steps to Resolve Error E-01: Step 1: Turn on/off the printer power button
Turn the power off. Wait for a while then turn on it again.
Step 2: Managing the lock of the printer
Store transportation lock carefully.
Step 3: Managing the CD tray
Press the CD Tray button to retract the tray to its original storage position. Be careful never to push or pull the CD tray into the wrong position. Turn off the Epson Printer and make sure that there is no paper left which may lead to paper jam issue inside the unit.
Step 4: Checking the printer cartridge
If the printer is installed with the CISS then, make sure that its carriage is easily movable towards left and right side.
The printer's upper scanner part should be closed tightly.
Step 5: Perform a check-up process.
Install original Epson ink cartridges and then run the printer.
Step 6: Access the cartridge
Access the cartridge loading area while the printer is in off-mode and then, move the carriage right away from the stop. Carefully disassemble the printer and then, clean all its optical sensors, paper feed sensors, encoder strip as well as disc encoder.
You can get the restriction/unlock code for Nokia C1-01 from MobileUnlockSolutions.com . There you have to give your Country and current network name along with your IMEI number to get the restriction/unlock code.
After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
If your mobile is locked with security code then try to reset it with master reset codes from unlock-free and for Locked contacts try to go to near by service center to get rid of your problem..
Hi and welcome to Fixya,
The E01 error for your bosch indicates a door lock problem has been detected at the control board. Insure the door is closed tight, turn your breaker off or unplug the washer for a couple of minutes and retry. Let me know what happens, ultimately it may be a faulty lock assembly, a loose wire harness etc. but we'll cross that bridge when we get there...if necessary.
I'll watch for you to respond with the result's.
Good luck.
Macmarkus :)
