Hello there, i just owned a brand new Asus T100 for 2 days and today on the 3rd day after purchasing, i faced problems during boot/start up where the laptop gets frozen on the Asus logo screen.
I tried holding down the power button for 10 seconds and turned it on again. It ran a series of windows software updates before the start up, then after all software updates have been completed, the laptop resumed to freeze at the Asus logo screen again. I tried holding the power button for 10 secs followed by holding the power button and volume up button at the same time, to get into automatic repair/repair mode. THIS HELPS, get into the repair mode!
To cut it short, i tried the other advanced options as well as the restart button in the repair mode but to no avail. After carefully reading the different options in the 'advanced options' in repair mode... Here's what worked for me:
1) If you're stuck at the Asus logo screen which doesn't seem to boot for ages or at least 10 minutes, hold down the power button for 10 seconds and let the screen turn black. (I did this with my charger plugged in, not too sure if it matters)
2) Count to 10 seconds. Switch the laptop on by HOLDING THE POWER BUTTON + VOLUME UP BUTTON at the same time. This will send the laptop into an 'automatic repair', followed by a 'diagnosing this PC' and after which you will see a blue screen which is the repair mode.
3) On the blue screen you will see 2 buttons, 'Restart' and 'Advanced Options'. Click on 'Advanced Options'. (DO NOT CLICK RESTART, it does nothing as you will get stuck again at the logo screen)
4) After clicking 'Advanced Options', click 'Advanced ....' (i forgot what exactly) and click 'STARTUP REPAIR'. This is the crucial part.Then follow whatever the system promts you.
5) Afterwards, it will attempt to repair your system then lead you back to the logo screen for startup.
6) Wait a few minutes and you should be able to get to your login screen as usual.
Hope this helps. I chanced upon it by guessing which would actually help me.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
were you trying to unlock or jailbreak it ? be that as it may remove the battery for about 10 minutes and then try and turn on the phone again. should work unless the error occured while you were doing either of those two things
go to www.modchipman.com for repairs it has exactly what your talking about i used them for my 2 360 repairs and they turned my ps3 backwards compatible. =)
Problem: An update being pushed out to EEE PC 701SD causing machine not to load to full GUI Symptom: Machine will start to load into GUI but will get stuck after loading taskbar. To fix: Open the Terminal window by pressing Ctl-Alt-T. Enter the command 'sudo apt-get remove asus-p901-system-update azurebt' Press power button to turn off machine. Turn machine back on, open the terminal window again with Ctl-Alt-T. Enter the command 'sudo apt-get install asus-eeepc-core' Restart the machine.
