Washing Machines Logo
Kevin hankey Posted on Aug 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I find the serial number of my Hisense top loader washing machine
L Pfaff
Level 3:
Top Expert:
  • Washing Mach... Master 11,573 Answers
  • Posted on Aug 27, 2016
L Pfaff
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3585370
Points
181713
Kevin, wash machine # tags can be found
  1. Under lid, near the right hinge.
  2. Exterior, on the back of the control panel.
  3. Exterior, bottom left corner.
  4. Exterior back, near the water inlets.
  5. Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Finding Your Appliance Model Serial Number
https://www.reliableparts.com/sections/locating-the-model-number-on-a-top-load-washing-machine
Washing Machine Repair Services Southland Technical Services LTD...
Thomas Perkins
Level 3:
  • Master 15,088 Answers
Thomas Perkins
Master
Level 3:
Answers
15088
Questions
0
Helped
3386499
Points
54869
5 Related Answers
A
Anonymous
  • Posted on Feb 25, 2008
SOURCE: moffat washing machine older really older cant find model number
clothes need be more drye ofter end work
Anonymous
  • Posted on Aug 07, 2008
SOURCE: Kleenmaid top loader Washing Machine Mod KAW 793W leaking
Problem turned out to be a leak from the top, not the bottom and was caused by debris blocking an overflow trap
Anonymous
  • 5911 Answers
  • Posted on Jan 17, 2009
SOURCE: how to take apart a Whirlpool top loader washing machine
If you have not taken the exterior washer casing off, the first steps will explain how to accomplish this:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Once the casing is removed, you should have full access the the washer interior components. Since you have mentioned you taken the "internal post" off (I'm assuming this is your agitator), I will spare the steps in involved in accomplishing that task.
Next, follow these series of steps:
1. Remove the tub ring. This is the cylindrical donut shaped ring attached to the top of the wash tub. This ring needs to be removed in order to accommodate the removal of the inner spin basket. The tub ring comes off by placing a screwdriver under the series of the tabs that hold it in place and GENTLY prying them up until they release. Be careful not to break off the tabs, or crack the wash tub.
2. Remove the spanner nut that is under the agitator. This holds the inner spin basket to center post.
3. With the spanner nut removed, the spin basket should lift straight up and out. Sometimes the basket will stick to the center-post and may required some "coaxing" to get it free. This can be accomplished by grabbing the rim of the spin basket and prying up on one side, then the other, in an attempt to rock the basket side to side.
Searspartsdirect.com has excellent exploded view diagrams that you can use as a reference. Simply type in your model number and look under the "Agitator, Basket and Tub" heading. The tub ring gasket, I mention below, is listed as item 6. Appliancepartspros.com also has these same drawings.
Some things to consider:
If you remove the tub ring, it is recommended that you replace the seal on the ring before reassembly. Once the tub seal is broken, it can leak if the seal is not replaced.
When reinstalling the exterior cabinet, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have questions, or need further assistance, please let me know. I hope this helps you.
PS What is the reason for removing the spin basket? Anything else I can help you with?
Anonymous
  • Posted on Jun 19, 2010
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Anonymous
  • Posted on Aug 10, 2010
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
1helpful
Hisense top loader WTCT802 8kg washing machine,
This could be down to a number of reasons. The most common of which is a displaced or faulty spin switch. This switch tell the machine that the lid is closed (or that the top is on a front loader). I know this may sound silly, but if you have a spin speed selector, double check to see that it's not been set to "0".
If neither of those work/fit the problem, and also if it is showing any error codes, eg. F01/F02/UNB, please let me know
Hi, our Hisense WTQ1602S washing machine does not take the softener. It also does not stop when opening the top.
This machine is not available in north America where we are. Top loaders usually have a centre pot for the fabric softener on the agitator or for the small machines with a rotary agitator at the rear, they have a small door. If the top door interlock doesn't work, it needs fixing if you have children.
I don't see a manual for it. This link might work better for you
https://www.google.com/search?q=hisense+wtq1602s+manual
1helpful
Beko washing machine causing pulled threads on my clothes model number WTL10415W
No model number given. Front Loader or Top Loader? Pulled threads are normally in front loader and is caused by a pinch point in one of the baffles. On a top loader, look for a nick in the agitator, or the type with a split agitator, a gap between the two parts.
2answers
My top loader Hisense washing machine doesn't wash but it spins, what is the possible solution?
If your Hisense top-loading washing machine is not washing but can spin out the water, it could be caused by a few different issues. Here are a few things you can try to fix the problem:
  1. Check to ensure that the washing machine is properly loaded and balanced. An unbalanced load can cause the machine to stop working or not wash properly.
  2. Check the water supply to the machine. Make sure that the water hoses are properly connected and that the water supply is turned on.
  3. Check the detergent dispenser to make sure that it is not clogged. A clogged dispenser can prevent the detergent from being dispensed and the machine from washing properly.
  4. Check the lid switch. If the lid switch is faulty, the machine may not wash but will spin out the water.
  5. Check the water level switch. If the water level switch is faulty, the machine may not wash properly but will spin out the water.
  6. If the problem persists, consider contacting Hisense customer service or a technician for further assistance.
It's essential to note that if the machine is not washing but it can spin out the water, it could be caused by a malfunction or damage in the water level switch, the timer or even the motor.
Hisense 16kg top loader. My washing machine is not washing but it spins and rinses.
Does it let water into the machine for the rinses?
Did you try removing the wall plug for 10 minutes to reset it?
It sounds like a control board issue or the wires that connect to it.
https://www.google.com/search?q=Hisense+16kg+top+loader.+not+washing+but+it+spins+and+rinses&
I need hisense washing machine codes n resetting features
My hisense automatic top loader can not finish a process, it stops mid way, is no longer fuzzy logic, any help?
2helpful
Model and serial number
If this is a Whirlpool manufactured TOP LOADER (such as the one you posted this question under), the model number and serial number are located on a nameplate along the wash tub rim under the lid.
If this is a FRONT LOADER, the model number and serial number will be located along the door facing as you open the door.
If you have questions, please post back and let me know. I hope this helps you.
2answers
Find serial and model number
Normally on top load machines open the lid and look toward the back hinge area inside the lid. It is usually on the back there. It may also be posted on a white sticker on the back of the machine.
Top Washing Machines Experts
john h
