Cars & Trucks Logo
bongani mnikathi Posted on Aug 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT IS CLIMATE CHANGE AND WHAT ARE THE EFFECTS OF IT
I am interested in knowing the definition of climate change and what causes it
Thomas Perkins
Level 3:
  • Cars & Trucks Master 15,088 Answers
  • Posted on Aug 26, 2016
Thomas Perkins
Level 3:
Answers
15088
Questions
0
Helped
3389056
Points
54869
Is this a hoax: australian pm adviser says climate change is 'un-led ruse to establish new world order'
probably not
the Australian PM is being led by the nose by the fossil fuel giants and refuses to acknowledge that there is a climate change problem
His government has in fact reduced funding and crippled the climate change council so that they cannot report to the people
the so called "new world order " is already starting around the world by every day people who are sick and tired of the wealthy destroying the planet in the name of profit
I have a 2001 Intrigue with Dual Climate Control., Went to start it one cold morning and there was no heat. I could hear the vents change but air was moving. What is the cause?
look under the bonnet and the heater control valve is electricaly operated and i think their may be a fault here for whatever reason
My climate control only blows out cold air but the rear climate control works as it should
Could be the controller or a faulty blend door.
The blend doors direct air thru the heater core and evaporator along with the vents. The controller uses electric motors to change the direction of air flow.
3helpful
Heater switch replacment
Hello! it's my job to make things as easy for the customer as possible...Therefore I must ask why you want to replace the heater switch? Is it because you have lost one or two of the switch speeds? Your vehicle is noted for loss of the Blower Motor Resistor...
Changing the Heater switch means removal of the Climate Control Assembly which is not the easiest of jobs...I've included the process...But are you sure the blower resistor is OK? If you have lost 1,2, or all blower motor speeds it's more than likely the Resistor pack. And a lot easier to change...
Guru...saailer
Remove climate control:
  1. Remove the instrument cluster finish panel...
  1. Remove the 3 climate control assembly screws...
  1. Disconnect the climate control assembly vacuum connector...
  1. Disconnect the 5 climate control assembly electrical connectors...
  1. Remove the climate control assembly..
Removal of blower motor Switch:
  1. Remove the blower motor switch knob.
  1. Remove the blower motor switch.
    1. Remove the screw.
Removal of blower motor Resistor:
Blower Resistor is under the battery tray...
MOTORCRAFT Part # YH1698 ...cost $25
Guru...saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
5helpful
Had to change out battery now climate control not working
Climate control need to be reset, turn all functions off and set all switches to CCW position. Disconnect battery for about 10 minutes, reconnect battery and don't touch any controls for several minutes. You may hear the climate control cycling at this time.
I believe the radiator is leaking water. How would I change it, and what type of radiator should I buy to replace it?
YOU WILL NEED A HAYNES REPAIR MANUAL.IT WILL SHOW AND TELL YOU HOW TO REMOVE RADIATOR.I DONT KNOW YOUR CLIMATE.IF YOU LIVE IN VERY COLD CLIMATE.YOU NEED MORE ANTIFREEZE IN COOLANT SYSTEM THAN WATER.WATER WILL FREEZE CAUSE PROBLEMS.
Climate control blows cold on one side and hot on the other should I buy a new climate control?
this is caused most often by out of phase climate zone blend door actuators, it is a very hard problem to repair, some luck in fixing it comes from removing the negative battery cable for 5 minutes to try and re-phase/sync the door actuators,if the one door will not change temp then it is more than a door sync issue and can require replacement of the blend door actuator, are the outputs of the 2 sides just reversed? that is to say will they change from hot to ac even though one is hot and one cold and visa versa?
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
