Question about Casio Watches
I have casio watch 2515..i change the battery but it didnt work..
  • Casio Master
  • 14,749 Answers
SOURCE:
  • 183 Answers
SOURCE: Changing the battery on My Casio watch module 1848. Two
The contact springs most likely have nothing to do with your screen being black.
The watch will have an "AC" or all clear function that needs to be performed. Check the back lid for AC or reset instructions. If there are no instructions there then you will have to visit a watch repairman/technician to have this procedure performed as it involves touching the AC pad on the circuit board to the back of the battery already installed. The circuit board is easily damaged if not performed properly.
Posted on Sep 17, 2009
  • 8081 Answers
SOURCE: Casio Waveceptor 2734 WVA-105H watch not working
You can use the manual to manually reset the time. After you succeed in setting UK time zone, wait until midgnigth: it should synchronize itself with the time signal from Germany. If unsuccessful to do so, it will keep attempting to synchronize itself at 1, 2, 3, 4, and 5.
Read the manual to figure out how to place the watch on a window sill. It might be better to be outside.
Keep in mind that the success of the operation depends on meteorological conditions.
Good Luck.
Posted on Feb 05, 2010
  • 15 Answers
SOURCE: Casio DBCW150-1 Databank watch (battery change)
DONT THROW IT AWAY THAT IS A COLLECTORS ITEM... You can get it taken care of at www.casiowatchrepair.com or call them toll free 877.659.0761 and have them take care of it, the watch will be as good as new.
Posted on Feb 23, 2010
SOURCE: I have a Casio DBC-60. I changed the battery because was not working for long time, but the watch stil is not working
This is an old problem, but maybe this will help someone changing a battery on a Casio. Many Casio watches must be "zeroed out" by putting an pointed tweezers between the back of the battery and the AC terminal off to the side of the battery. On my old Casio Telememo 50, the AC terminal is in a very small hole just above the battery. On the Baby G force, it was in a wider opening, way at the edge of the watch. It has something to do with resetting the watches circuitry so it will operate again. Good luck!
Posted on Sep 07, 2010
SOURCE: Casio 1170 ATC-1200 watch needs to have batteries changed
I'll post in case somebody still needs this. This is the general procedure to switch the ATC 1200 from meters to feet. You can also switch the ATC 1200 (1170) from C to F. This is very helpful if you change the batteries and the watch gets reset to meters.
Also note, when you pull out the two batteries, you may not get the watch to come up. This is because of a race condition when the watch gets power. To fix this, look for the AC mark on the inside of the watch. Under this marking, in a little space to the left, are two copper pads. Short this out with a small screw driver to get the watch to ground zero.
To fix the Metric measurements:
1. Go to the home screen on the watch. This is when the the 3 letter abbr for the day is at the top. Also, if you cycle the mode button, it is the screen where the final beep is "high."
2. Then press the "memory" button, which will take the home display to the data screen. This shows current time, pressure and temperature.
3. Hold down the adjust button, until the set screen comes up.
4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
You can adjust all the measurements from this screen.
Posted on Dec 30, 2010
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
Casio CPW-500H-1AV analog watch not working
That certainly wouldn't hurt - be sure you use good new batteries.
Aug 06, 2014 | Casio Watches
How do I replace the watch battery for Casio DW-6900?
mcdevito75 here, Casio uses an LCD crystal, Liquid Display Crystal, during a battery change any, any un do pressure remopveing or replaceing the battery could destroy the LCD. Take my advise, with a casio watch, look for a small watch repair shop in your area for the battery change. I"ve ruined many of my casio watches during battery change.
Aug 27, 2010 | Watches
How do I replace the lithium battery in a Casio Privia PX-100?
mcdevito75 here, I've also riuned a number of Casio watches replaceing the battery, extra, extra care is needed, first remove the back cover screws, then you:ll have to remove another cover for the battery, after replaceing the battery the work begins, very carefully reverse the removal procedure, any un do pressure will cause the movement to break and the face of your watch will turn Black. Best with your casio is to let a watch repair shop change the battery, look for a small shop to save some money.
Jun 14, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Need a user's guide for a recently purchased Casio watch [2515] D8-360, 4 button, silver, square face, illuminator, with reverse and forward buttons. Thank you.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIOwatch manuals.Rate me, please..
Mar 29, 2010 | Casio Watches
May 14, 2009 | Casio Watches
Casio G-Shock GW-300 2608
Change the battery. This happened with mine along with the battery needing charging more frequently. In my opinion, Casio's assertions that you won't need to change the battery is pretty much of a joke. My jewler concurred.
After changing the battery I can now press the light switch button and the watch works normally.
Tony
Feb 25, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Casio pro-trek PRG-60T Buttons no longer activate anything.
Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Feb 19, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Watches Logo
275 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Are you a Casio Watch Expert? Answer questions, earn points and help others
