The metronome speed is controlled by the Tempo setting. The metronome controls only adjust the volume of the metronome and if the metronome is heard on the input or output recording. The R24 manual is available here: http://www.zoom.co.jp/downloads/r24/manual/ . See page 20 for setting the Tempo. The Tempo button is below the Tempo label to the left of the LCD display on the right side of the Zoom R24.
If you have the beat generated, and merely want to save it, press Write Button once. Use the tempo up and down arrows to select the memory location and press the Write button again. it should store it.
If you are just looking for a different random shuffle, the metronome is hard coded and limited to what you can change on it.
If you did not get the owners manual, it is here: http://media.rolandus.com/manuals/DB-60_OM.pdf
I'd say the click track starts from exactly when you hit play even if you've hit play not right on the beat. There might be a setting or preference that can fix this.
Try rewinding back to be right on the beat and see if it syncs with the click
Press the "click" button and then set the tempo you want, press the "click" button again this will stop the metronimoe but is also sets the tempo in memory. The next time you press the "click" button it will be ready to go.
Anytime you press the tempo + or - it thinks you are trying to use the "Tap Tempo Function".
It sounds like the sensor is bad in the unit... If you have only had it a few weeks, exercise your warraaanty for replacement. Repairing the piezo sensor is NOT really a DIY project.
You hold down the function key/button and then use the PIANO keys with the "tempo" shown above them.
In that section of the keyboard, the C# key raises the tempo and the C key lowers it. You can also use the numbered keys in that section to dial up a particular value. Hold function down and strike the numbers you want then release the function key/button
I don't believe there is an adjustment for loudness of the metronome other than the overall loudness of the piano..
Hi I just got a RC 50 and I face the same problem but looking the content of the data in the Roland folder (after you connect the USB) , I notice the format of the label of each sound's and I understood the problem.
So , here it is .
Before you connect to USB , you have to choose a patch , let say n.16 OK, now the audio file that you want to import into the data folder must be named in this way "016_1.WAV" ,the 16 refer to the patch number and 1 is the phrase number (if you want to put the audio file into the phrase 1 ,or 2 if 2 ecc.)
now disconnect the USB .At this point you just have to increase or decrease the patch number just one time and go back to 16 (it has to refresh the patch info) and you'll find your audio file ready to use in whatever phrase you put it.
have fun
Paolo
