RIM BlackBerry Torch 9860 Logo
S
STEP GARE Posted on Aug 24, 2016
How do I reset all the applications after wiping out?
How do I do a factory reset on a SCH-R830C
Performing factory data reset ( master reset or hard reset ) Samsung Galaxy Admire 2 SCH-R830C via External Hardware keys buttons by Entering Android System Recovery:
  1. Turn off the device
  2. Remove the battery about 10 second and reinsert, remove sim card and sd card
  3. press and hold both the Volume Up key and the Power key until theSamsung logo is displayed.
  4. Press the Volume Down key to scroll to wipe data/factory reset.
  5. With wipe data/factory reset highlighted, press the Power key.
  6. Press the Volume Down key to scroll to Yes - delete all user data.
  7. Press the Power key to confirm.
  8. Press the Volume Down key to scroll to wipe cache partition.
  9. With wipe cache partition highlighted, press the Power key.
  10. Once the wipe is complete, press the Power key to select reboot system now.
Warning! All data will be erased from device memory, including system and application data, settings and downloaded applications. Back up your important data. The device will restore to factory settings.
tip
How To Reset Your Blackberry Smartphone
<span style="font-weight: bold;">Soft Reset</span><br /> <ol> <li>Press and hold the <b>Alt</b> key. </li> <li>While holding down the <b>Alt </b>key, press and hold the <b>Right Shift</b> key. </li> <li>With both of those buttons still pressed, press the <b>Backspace/Delete</b> key.</li> <li>The display turns off to indicate that the reset has started, and the keys can now be released. </li></ol><span style="font-weight: bold;">Hard Reset</span><br /> <ol> <li>Remove the battery cover. </li> <li>Remove the battery, and then reinsert it after a few seconds. </li> <li>Replace the battery cover.</li></ol><span style="font-weight: bold;">Factory Reset</span><br />The following will delete all data and applications on the BlackBerry smartphone. Back up the data on the BlackBerry smartphone before proceeding. The process for deleting all data and applications can take up to an hour to complete. Do not remove the battery while data is being deleted.<br /><br /> <br /> <b>Note:</b> To identify the version of BlackBerry Device Software on your BlackBerry smartphone, go to <b>Options</b> &gt; <b>About</b><br /><br /> <p style="font-weight: bold;">BlackBerry Device Software 2.6<br /> Note:</b> If a password is already set, go to step 5.<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b>. The Device Options screen is displayed. </li> <li>Click <b>Security</b>. The Security screen is displayed. </li> <li>In the Password field, press the <b>Space</b> key to enable the password. A dialog box will prompt for a password with at least four characters. </li> <li>Type a password. Click the trackwheel. Type your password again to verify it. </li> <li>On the Home screen, click the <b>Lock</b> icon. The Lock screen is displayed. </li> <li>Type your password incorrectly 10 times to trigger a security wipe. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 2.7<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b>. The Device Options screen is displayed. </li> <li>Click <b>Security</b>. The Security screen is displayed. </li> <li>Click the trackwheel, and select the <b>Wipe Handheld</b> option. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 4.0<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b>. The Device Options screen is displayed. </li> <li>Click <b>Security</b>. The Security screen is displayed. </li> <li>Click the trackwheel, and select the <b>Wipe Handheld</b> option. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 4.1 to 4.2.1<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security Options</b> &gt; <b>General Settings</b>. </li> <li>Display the menu and select the <b>Wipe Handheld </b>option. </li> <li>Click <b>Continue</b>. </li> <li>Type <b>blackberry</b>, and then press the <b>Enter</b> key. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 4.2.2 to 4.7<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security Options</b> &gt; <b>General Settings</b>. </li> <li>Press the <b>Menu</b> key, and select the <b>Wipe Handheld</b> option. </li> <li>Select the <b>Include third-party applications</b> check box to remove third-party applications. Clear the check box to preserve third-party applications. </li> <li>Click <b>Continue</b>. </li> <li>Type <b>blackberry</b>, and press the <b>Enter</b> key. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 5.0<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security Options</b> &gt; <b>Security Wipe</b>. </li> <li>Select the appropriate check boxes to remove data and applications as intended. </li> <li>Type <b>blackberry</b>, and click <b>Wipe</b>. </li></ol> <p style="font-weight: bold;">BlackBerry Device Software 6.0<br /> <ol> <li>From the Home screen of the BlackBerry smartphone, click <b>Options</b> &gt; <b>Security</b> &gt; <b>Security Wipe</b>. </li> <li>Select the appropriate check boxes to remove data and applications as intended. </li> <li>Type <b>blackberry</b>, and click <b>Wipe Data.</b> </li></ol><br /><span style="font-style: italic;">To reset a legacy BlackBerry device (</span><span>Research In Motion&reg; (RIM&reg;) 850, 857, 950, 957 devices)</span><span style="font-style: italic;">, insert the end of a paper clip into the small hole on the back of the device.</span><br />
on Feb 15, 2011 • Cell Phones
Kyocera edge 3g how I unlock emergency pin I forgot it
Perform a hardware factory reset
A master reset will result in the loss of all data stored on the device including 3rd party applications.
With the device turned off, press and hold the Volume down key.
Note: To turn the device off completely, remove the battery.
With the Volume down key held down, press and hold the Powerkey. Release the Power key when the Android system recovery screen appears Use the Volume down key to scroll to wipe data/factory reset.With wipe data/factory reset highlighted, press the Power key.Press the Volume down key to scroll to Yes -- delete all user data.
With Yes -- delete all user data highlighted, press the Power key.Once the wipe is complete, with reboot system now highlighted, press the Power key.The device will restart.The device is now reset and ready for use.
Jan 26, 2014 • Cell Phones
How can I reset backyberry 9860 touch
One type of reset requires that you simply remove and replace the battery - this forces a reboot of the phone which does not happen when you turn it off and on with the power button.
A full reset & wipe (restores your phone to factory) is done like this:
On the Home screen or in a folder, click the Options icon.
  1. Click Security > Security Wipe.
  2. Perform any of the following actions:
  • To delete data from the messages application, contacts application, and other applications, select the Emails, Contacts, Etc check box.
  • To delete all third-party applications that you have added, select the User Installed Applications check box.
  • To delete all files from your media card, select the Media Card check box.
4. Type blackberry.
5. Click Wipe.
How can you be sure an old smart phone has no information before disposal
You can reset the phone.It will erase everything.
  1. On the Home screen or in a folder, click the Options icon.
  2. Click Security Options.
  3. Click Security Wipe.
  4. Perform any of the following actions:
5. Type blackberry.
6. Click Wipe.
http://www.resetcellphone.com/solution/Blackberry/storm-9530
I wont to reset my palm my phone
A Hard Reset (Full Erase) will erase installed applications, application settings and data.
  1. From the Home screen, touch the launcher icon.
  2. Touch Device Info > Reset Options > Full Erase > Full Erase.
Steps to Perform Remote Hard Reset
This can be performed from your Palm profile online.
  1. On your computer, go to palm.com/support
  2. Enter your Palm profile email address and password.
  3. Click Wipe Device to remotely reset your phone.
http://www.resetcellphone.com/solution/Palm/pre
2helpful
How do I reset my blackberry 9530 to original settings and clean my info from phone
CAUTION: If you have turned on encryption, the process for deleting all device data can take up to an hour to complete. You cannot stop the process after you start it. If you reset your device, the process restarts after the device restarts.
5. Type blackberry.
6. Click Wipe.
3helpful
My Blackberry is hanging on the Memory cleaning application. The front screen shows only the ''Timer''. When the phone is reset and the sim card removed the phone keeps going back to the same screen....
Dear user,
This type of problem came by the downloading of third party software which is not compatible with your device or Blackberry .
You have to delete some application form your device , which is not compatible of your device.
Or you have to reset/format your device .
How to delete third party application :
1 in screen menu è press “Option”
2 press “Advance Option”
3 press “Applications”
4 select third party application (which is in bold letter)
5 press the “Menu” key and Delete.
Please follow the below instruction “How to wipe the device”
2 Press “Security Options”
3 Press “General Setting”
4 Press the track wheel and select “Wipe Handset”
5 If you like to include the third party software , please check mark on “include third party application” then press “continue”
6 Type “blackberry” then press the track wheel and select OK
Your device is formatting now >>>>>>>
2helpful
Cant open the inbox messages for sms.
pls reset the device i mean master reset to factory default and then this problem will vanish and first backup ur data bcoz it will wipe off
980helpful
7answers
How do i reset blackberry curve 8330 to factory settings
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
