A
Anonymous Posted on Aug 23, 2016
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
I have a Panasonic Home Theater whose dvd reader is broken. I need to connect the active subwoofer SB-WA340 to a newer philips dvd reader but the cable seems too old for such new dvd reader. Is there any other way to get them connected? Thank you
bigdawg7299
Level 3:
  • Master 2,559 Answers
  • Posted on Aug 23, 2016
bigdawg7299
Master
Level 3:
Answers
2559
Questions
0
Helped
555758
Points
7776
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
I have a panasonic sa-ht 700 but it did not come with a power cord. it does not have a 120 plug in like normal
The SA-HT700 is the main unit for the SC-HT700 DVD Home Theater system. For this system, the sub-woofer (SA-WA340) has the AC power connection. The sub-woofer is connected to the main unit by a "System cable". The power cord and system cable are shown in the manual. You'll need the sub-woofer if you don't have one. Amazon has a used sub-woofer listed here: https://www.amazon.com/Panasonic-SB-WA340-Powered-Subwoofer-SA-HT700/dp/B076HB8HQP . However, I don't know the third-party vendor.
A replacement power cable for some regions is available at Amazon here: https://www.amazon.com/Polarized-Panasonic-SA-HT700-SA-HT80-SCHT1500/dp/B00VFHP9US . I found the system cable here: https://www.amazon.com/Matsushita-Panasonic-K1HA25HA0001-CABLE-65/dp/B001DPHPCC . See the manual for the correct part numbers: ftp://ftp.panasonic.com/hometheater/om/sc-ht900_en_om.pdf . The accessories that come in the box are shown on page 3.
I hope this helps.
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
6helpful
2answers
3answers
Panasonic dvd player for subwoofer
I have a SA-HT 690 system with a bad SB-WA342 sub. I can sell you my player or buy your sub.
Panasonic Sub Woofer
I Have the sub woofer SB wa 340, but I need the remote control if posible bussines send me the information 7862873227
Subwoofer
is it just the sub you have or do you also have the dvd unit with it?
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
