Kenwood KM800 Major Classic Stand Mixer Logo
L
Linda Posted on Aug 23, 2016
Hi with my kenwood major, the beater goes slow then faster then slow again could it be the gear box
1 Related Answer
J Grant
  • 246 Answers
  • Posted on Jun 28, 2012
SOURCE: I need a apart part for kenwood major a 171C. The shaft where the beaters connect to machine is broken cogs etc are fine
This is the only thing I could find in order for you to get parts...This is their phone number in UK..Kenwood Spares Distribution Centre on 0870 241 3653 If I uncover anything else I'll let you know...
1helpful
Hi,we have an old kenwood chefette hand mixer with worn parts.
does anyone know how I could get the whisk beaters for a Kenwood A375? Was given mixer but no whisks!!
10helpful
3answers
K-beater is stuck on our Kenwood Chef and we can't remove it
I couldn't remove the K-Beater as when I tried to turn it the whole mechanism turned with it. I couldn't even remove the splashguard! I was going to take it to the Kenwood factory (a few miles from home) but then I thought I'd give it one more go and this is what I did...
  1. Next to where the K-Beater attaches in the middle of the circular plate is a lug with a pointed-shape bolt on the end. Remove this with a spanner and the beater plus gear cog can be removed.
  2. Place some mole grips or wide pliers on a worktop and sit the cogged gear in to it and grip so that it won't turn.
  3. Now you should be able to remove the K-Beater!
Perhaps someone can suggest how to stop it happening again. I haven't attached anything since but will update this post if I have any other helpful tips.
New Kenwood chef km 001 - I can't get the beaters out!
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
Kenwood Mixer A702
There are not any new parts from Kenwood to A700 series, try to find it on internet or if anyone in the forum has one.
Kenwood HM 220pk100/W
There are not any spare part more than Beaters, Kneaders and Beater gears to this machine.
1helpful
Noisey
You have to take off the top on the gearbox, then you have all gears in front off you.
It´s correct that you should use vegetable based grease, the spare part number Kenwood use for this is: KW630879
Kenwood Major Mixer
Thank you for your time. I contacted the Kenwood company in England.
2helpful
Kenwood chef.mixmaster
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
2answers
Beaters fall down
You have to change the planet hub and the beater.
Top Kenwood Food Mixers Experts
vince
Ngoro
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
