Cooktops Logo
C
Cquo Posted on Aug 23, 2016
Dcs sc305 oven door locked
Ovn door locked
Dcs oven wos130 wont reach set temperature on bake
Good afternoon Steve!
The answer may depend a bit on what you mean by 'stops heating'.
  • One interpretation could be 'the heating shuts off, and the oven goes back toward room temperature
  • The other would be that it heats up, but it heats to a certain temp and then stays there. it's just not as hot as it's supposed to be.
If it's the former, that sounds like something is overheating and an interlock is engaging because it's interpreted as 'I'm too hot where I shouldn't be, and I should shut off before I cause a fire. I'd leave that to a better trained service tech.
If it's the latter, then it'll depend on how low it is. If it's way low, then there's a couple possibilities:
  1. The heater element is defective, and even at the full current draw the oven can run, it can't get any hotter than that upper temp. This would mean replacing the element.
  2. The temperature sensor in the oven is defective or mis-mounted. There should be a temp sensor inside the oven cavity. if it's disconnected, or, say, bent out of place and much nearer the bake element then it should be, then the heat coming direct off of the element may be fooling it into thinking the oven is hotter than it really is. this could mean replacing the temp sensor, or just re-mounting it to proper position.
If it's just a bit low, then there could just be a calibration problem. If you look at the manual here
DCS WOS 127 Use And Care Manual Child Safety User Option you can see how to adjust the calibration up or down in temperature to, hopefully, match the oven thermometer you're trying to use as a check.
Hope this helps!
Good Luck
D
What does the F93 code mean and how do we fixt it
i know that it can be very difficult to have issues with your oven. the f93 on this model of kenmore range indicates that you have a problem with the oven door lock assembly (see image below). this can be caused by a failed oven door lock assembly, a wiring failure or a bad electronic oven control board.
i recommend that you unplug the range and check the wiring between the components first. you can remove the upper back panel of the range to access the electronic oven control board in the console. you may need to remove the lower panel to access the door lock assembly on the back of the range. the image below shows the wiring diagram and other information that should help you check the wiring connections. check for a mechanical binding of the door lock assembly as well. if the wiring connections are okay, you will likely need to replace the oven door lock assembly. if you need further assistance, please reply to this thread. thank you for using manage my life.
1helpful
How do i lock the self cleaning ge oven door when i put it on self clean
If you have a self cleaning oven, the door will lock automatically as the self cleaning begins. Give it some time ,it will happen. When cleaning is done it will take a while for the door to unlock. GOOD LUCK FRIEND.
DCS Burner Flame Height Control
I would check the gas pressure at the meter reg .It sounds like you are saying too much gas to burners
We have a dcs 48 inch range/oven and the main oven does not heat. The broiler does and the small side oven heats. Any advice?
You don't say if it lights up! If it lights up and stays on low it's the thermostat that's at fault, they are not adjustable and will need to be replaced.
DCS RGS slow to preheat
You didn't state whether you used a DCS conversion kit or not. I was able to find conversion instructions for a model similar to yours (not an exact match) but it will give you an idea as to what all is involved.
DCS RGSC 305 Instructions Manual
3helpful
2answers
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • 0helpful
    How do I know when my stove is done self cleaning?
    to get all the detailed instructions
    just click this link directly
    http://www.applianceaid.com/selfclean5.html
    The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
    Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
    If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
    thanks.
    6helpful
    Whirlpool self cleaning oven Accubake. 2 yr old
    Hi
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Top DCS Cooktops Experts
    Paul Carew
    ADMIN Andrew
    ADMIN Andrew
    Are you a DCS Cooktop Expert? Answer questions, earn points and help others
