Take them to a good quality shoe repairer and they will replace the sole.
https://appsync.biz/dafont/ https://192168ll.onl/ https://appsync.biz/filehippo/
For larger area repairs such as shoe soles, use the contact bond method:
Apply to one surface only, press together and pull apart. Keep apart until the adhesive film is almost dry (approx. 10 - 20 minutes).
Carefully line up surfaces to be joined and press surfaces firmly together. Bonds immediately on contact.
Take it to a shoe repair shop and have them look at it. There are different kinds of glue we have that can take care of it.
Do you have a a pair of shoes that you bought not too long ago and the sole is coming apart? If you rather not risk buying another pair of the same shoes only to have them come apart, then this is the article for you.
Difficulty: Easy
Instructions
Things You'll Need:
1.
Get a tube of super glue--any brand name should do. Just the regular type should do, no need for any extra strength formulas or special types. Make sure the tube has been properly opened at this time--the seal on the tube has had a hole punched in it, in other words.
2.
Get the shoe(s) that need its/their sole(s) fixed. Where the sole is coming apart on the shoe, squirt in a good amount of super glue, but not too much that it will gush out. (If it does, try to wipe off the excess).
3.
Hold the sole and shoe together for the recommended drying time or until they seal. Try not to get any glue on your fingers at this time, as it can stick flesh to other objects.
4.
The sole should be fixed at this time. Sometimes it has to be done over if the drying time hasn't been followed or the glue might have some problem with it. Repeat this procedure for other shoes to be fixed
Difficulty: Easy
Instructions
Things You'll Need:
1. 1
2.
3.
4.
apply the same proedure for your broken part insted of repacing it
