Question about Hyundai Car DVD GPS for IX35
Calibration of centre console screen on an ix35 highlander and nav problems
From the get go i have had problems with our centre console from clock not showing the correct time to the calibration of the screen on the right hand side being off. we have also had problems with the nav system not being able to find satellites on clear days. i am wondering if there is anything i can do to fix this as Hyundai have been no help and now that the warrant has expired are no longer willing to replace
  • Hyundai Master
  • 10,543 Answers
Go to Hyundai motors factory website and explain this to them. They might get the dealer to fix it since the problem was never fixed correctly before the warranty ran out.
Posted on Aug 22, 2016
SOURCE:
Problem with rear Suspension IX35 Hylander
could be the rear shocks, but if you read the owners book. they don't suggest having heavy loads. 30kg does not seem like a lot. have you tried an 4 wheel alignment. first they can tell you if it needs one. second if there is a problem they should tell you what needs to be fix.
Jan 22, 2015 | Cars & Trucks
Tom tom screen calibration for 9.510 Nav Core version
cant be done, if the touchpad is out of synch it needs to be replaced.
Sep 08, 2014 | Tomtom GPS
Radio stopped working
check fuses first if none are blown then you well need new nav and radio
Jan 28, 2014 | Toyota Highlander Cars & Trucks
Removal sat nav screen
disconnect battery. remove 1 gearshift surround held by clips. 2 centre glove box liner, 3 rear console air vent. 4 centre console held by screws. audio stack held by small bolts. make sure you remove gearshift from P before you disconnect battery,
Oct 19, 2013 | Jaguar S-Type Cars & Trucks
Hi there, My Hyundai ix35 has the bluetooth console and my owner's manual is for the non-bluetooth version. As a result, the way to set the clock is not in the manual and not obvious. Unfortunately I can't...
Nice & easy- Have your radio switched on. Push & hold the volume knob for 3 seconds. It should now say Initial volume setting (or something of the like), scroll to the right & it should say clock setting, press the volume knob again. Turn the knob to change the hour figure, press the volume knob again for minutes and press the knob again to set.
Hope that this helps
Apr 20, 2011 | 2011 Hyundai Tucson
How to set digital clock on ix35 Hyundai highlander
Turn the radio on.
Hold down the volume knob for 3 seconds.
The display will come up Volume Setting
Rotate the volume know clockwise until the display switches to time setting.
Push the volume knob.
Rotate the volume knob to select the hour
Push the knob
Rotate the volume knob to select the minute.
Push the knob.
Done.
Nov 30, 2010 | Car Audio & Video
2006 Toyota Highlander Limited - Where is the NAV main unit located? I have an update disc - but can't find the brain.
The Nav ECU is under the Driver side front seat. This is where the Nav Disc goes into.
Dec 30, 2009 | 2006 Toyota Highlander
Screen calibration
u may have to change the screen but iam not to sure where about they can be purchased but its a risk it might damage the ds. u may have to buy a new ds
Dec 26, 2009 | Nintendo DS Lite Console
2006 Navigation SYstem DVD stuck
remove all wood grain and plastic
Jul 26, 2008 | 2006 Toyota Highlander
Hyundai Car DVD GPS for IX35 Logo
768 people viewed this question
Top Hyundai Audio Players & Recorders Experts
ka4iup
ka4iup
Andrew Taylor
Andrew Taylor
moony
Level 1 Expert
Are you a Hyundai Audio Player and Recorder Expert? Answer questions, earn points and help others
