I bought a used 2005 Kia Sedona with really low miles (88k). Ever since I bought it it has had issues with stalling, not starting, cutting out while cruising or at idle. Dealership has replaced everything but the fuel pump. They also jumpered a wire from a blank relay to the fuel pump relay. Why?
They used the jumper wire to make sure that the fuel pump was running. For engine to run you need compression, air, fuel ,ignition.
Your problem lies with either fuel or ignition, and if you dealer cannot fix but continue to charge you, I would suggest you go elsewhere.
