It connects with Internet but keeps switching itself off.
SOURCE: I have the new ipad. I can't connect to the
You have to manually setup the ip address in the network settings. The router that you have can not assign the iPad an address.
SOURCE: hello, my Ipad hase Wifi message,but
If your ipad is connected then it might be that your router needs to reset or your internet is down. Just unplug your modem and router for 5 seconds then plug in and see if that helps it. Check if your computers can connect to the internet.
SOURCE: I had bought an ipad
I was very happy when I got my hands on the new iPad. I didn't notice this at first, but when I took the tablet into my backyard, and my iPhone was able to pick up my router signal without a hassle; the iPad didn't pick up the network at all. This became a nightmare for me. A friend suggested trying the "Forget This Network" reset method, which used to work on the older models, but this didn't improve the wifi range at all. Right when I lost all hope, I came across WIRED magazine and found a review of Pong Research cases, After seeing the great feedback on their products, I bought one and it finally solve the <a href="http://www.pongresearch.com/new-ipad.html">new iPad 3 wifi issues</a> . The back cover has a built-in antenna in between its layers, which redirects and boosts the signals and range, allowing me to getting connected from much further away.
SOURCE: iPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
SOURCE: My ipad mini keeps shutting off
I would first try doing a hard reset. Hold the home and power button down simultaneously until the iPad completely turns off and the Apple logo appears. You can ignore the slide to turn off button when it appears.
If that doesn't solve the issue I would make an appointment with your local Apple Store and have the device checked out by an Apple Genius.
Hope that helps!
