Electrical Supplies Logo
Dan Green Posted on Aug 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Generac NP 50G hard to start. When it does start runs for awhile then rpm starts to go up and down.
  • Dan Green Aug 20, 2016
    I have replaced the carb, plug and coil and it still does same thing. After it runs about 30 minutes
  • Dan Green Aug 24, 2016
    Check the fuel lines, replaced fuel pump and filter and hooked up to fresh tank of fuel and new fuel line and still same thing. Any other ideas?
Bill Boyd
Level 3:
Top Expert:
  • Generac Master 53,816 Answers
  • Posted on Aug 20, 2016
Bill Boyd
Generac Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11925303
Points
172802
Low fuel supply
check tap for internal corrosion/blockage
check filter at end of tap( in tank) for blockage
check hoses for internal failure
    Replaced carb, spark plug, coil and new fuel pump and filter. Cranks better but when put under load rpm goes up and down. Tried running from new hose and small tank of fuel and does same thing. Any other ideas?
4 Related Answers
Anonymous
  • 232 Answers
  • Posted on Oct 20, 2009
SOURCE: Generac NP 50G Stops after 2-30min.
check the oil sensor circuit. I know when I take out or short out the sensor ckt on mine, it'll keep on running. low oil isn't good for any motor.
Testimonial: "Parts are on order and will verify the fix. But this makes a lot of since based."
Anonymous
  • 4088 Answers
  • Posted on Oct 28, 2009
SOURCE: Generac NP 50G wont crank
Measure voltage drop across the far ends of the fuse wiring (should measure zero), as one of the wires or it's connection to either end of the fuse may be open. Check the battery negative grounding connection at the frame. If all ok, you may need to find a wiring diagram for the machine. Does this unit have a low-oil-level switch which will kill the engine if set?
Anonymous
  • Posted on Sep 06, 2010
SOURCE: RPM/voltage fluctuation on Guardian Primepact 50G
The voltage regulator board on this unit is notorious for failing. If you are handy, you can replace it yourself with basic tools and a voltmeter to set the output. The part is about 200 dollars. Good luck
roadtech7
Matt Olenzek
  • 297 Answers
  • Posted on Dec 04, 2010
SOURCE: I have a generac 50G.
This is the easiest way, get a hand held power drill and plug it into one of the 120 volt recepticals. Make sure all the cicut breakers are pushed in before you do this. OK here is the trick, with the generator running, pull the trigger on the drill and spin it hard BACKWARDS. You must keep the trigger pulled and DONT hangonto the chuck after you spin it......... It will just take off spinning. If it doesnt work at first do it again, if it does not work, make sure you are spinning it as fast as you can. If the drill motor does not just take off after three attemps, you might have a bad diode that needs to be replaced.
Hope this works, Let me know :)
Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Generac 14kw Lp mod 0055030 ser 5437842 Battery was dead. Replaced but has code RPM SENSE LOSS.
RPM Sensor Loss 1501
ALARM
This RPM alarm is set when a 2 cylinder unit was already running and stalled or lost the RPM signal from the ignition coils. Possible causes could be a fuel issue, the LP tank is empty, 1 or both ignition coils are damaged, or the unit was overloaded quick enough that the engine stalled and set the alarm.
Possibly a fuel flow issue.
Try running without load for awhile, if it faults with no load then either an ignition module or control board or fuel. If it only faults with significant load, then more likely a fuel flow or engine is stalling from sudden increase in load.
Generator hard to start and sputters like its missing
About 15,000 results (0.73 seconds) Search Results
    2 - Generac : Questions, Answers, How To, FAQs, Tips ...
    answers.generac.com/answers/1506-en_us/searchquestions.htm?...
    Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
    2 - Generac Questions and Answers
    answers.generac.com/answers/1506.../generac.../questions.htm?...
    On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
    3 - Generac Questions and Answers
    Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
    On auto start, unit sputters and I smell gas. On manual start ...
I have an older 30KW Generac SG 030 1800rpm running on Nat Gas which I bought used. It has set up for several years. I installed a new PN0830890SRV master control board I bought from the local Generac...
need to calibrate the main control board. 83089. also is it overspeed or overcrank? if the board does not see the right rpm or is blow a certain threshold it will think it has not started yet and shut down on overcrank.
I have a Generac NP-50G Generator with a broken push rod
The push rod should just go back in where the broken one was. They set into the tappet almost automatically. You can slowly spin it over to verify. I'd replace both push rods if it where mine.
This is a generic OHV " How to adjust the Valves" YouTube video which should take you thru the process.
Change the oil. Check/adjust the valve clearance at least yearly.
How to Adjust Valves on OHV Small Engines Valve Clearance lash
3helpful
2answers
2answers
go to www.zabatt.com - look in their Service manuals section - good luck!!
2008 Gaurdian Generac 3cyl diesel shuts off after hitting bump
If you dont find a solution here. Call Generac in Waukesha WI. and get the number for Robert Schwalm Co. He is the best in the Country for Generac I used to be #2 but I havent worked on all the new Generacs. Give me an old RV unit and no one is faster!
2helpful
2answers
Generac Generator won't stay running
It sounds like you are not producing any voltage. When you start your generator have a volt meter on the generator breaker to see if there is voltage present when the genset is running. Also, check you oil pressure switch, which is near the oil filter.
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
