Televison & Video Logo
A
Anonymous Posted on Aug 20, 2016
How to reset sharp 21V1-L eeprom
How to reset the eeprom on 21V1-L
Level 3:
Top Expert:
  • Sharp Master 76,851 Answers
  • Posted on Aug 21, 2016
Sharp Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987242
Points
237762
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
How do i find password of my 21V1-L Sharp tv?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
HOW DO I USE RCA REMOTE TO PROGRAM MY SHARP TV 21V1-L MODEL
Read the directions that came with the set/remote. If unavailable go to manufacturers web site for support and download copy of manual.
How to reset my sharp 21V1-L unlock code
To make it a system reset, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Sharp fo-2081 System error u2-00
U2 04 Content EEPROM serial communication
error
Detail Error in communU2 04 Content EEPROM read/write error (Serial
communication error)
Detail EEPROM access process error
Cause EEPROM abnormality
Check
and
remedy
Check that the EEPROM is properly set.
Use SIM 16 to cancel the trouble.
Replace the MCU PWB.
Sharp tv 21v1 l
Check its picture settings. Refer its user manual for details.
Sharp model 21V1-L 19 tv
The TV has been locked. Refer its user manual to get details about the default passcode.
Sharp 21v1-l unlock code
sharp tv 21v1 l codenumber
Sharp aquos 42 inch lcd, too much red thro certain areas in the picture that should be dark. I have heard it needs eeprom reset how would i do this please, if anybody could help xx
Contact Sharp to see if it can be a "reset" issue and to see if this is a known problem in this model----more likely than reset would be a possible software upgrade but it depends on what actual issue is---maybe a bad board somewhere in the set.
I have a 32 inch beko. bought second hand. been fine for 3 weeks but now when i switch it off it says turning off,please wait and last for 4.5 minutes!
Enter service menu using:
MENU, 9, 3, 0, 1
then goto EEPROM EDIT, and then EEPROM RESET, right arrow
to reset. Switch off. This should remove any eeprom corruption, causing the above fault
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
