Sony KDF-55E2000 Logo
Scott Mullen Posted on Aug 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How-to check a Lamp Ballast board on a Sony KDF-55e2000 TV for proper operation
TV was purchased new and only had a to replace the Lamp once after 2 years. I kept the original packaging and always used it to move it or store it in. This TV has always been handled with upmost care. TV was working fine before putting into storage for the past 2 years. It was originally put in an upright position, but got moved around while in storage and was left on its side for the past year. Recently it was moved from storage back to my home and when it was plugged-in the unit had no light and cycled off after a minute or so and the standby light started flashing a red code 5 times. Looked-up the code online and it said the problem was the Lamp Ballast. Don't understand how it would go bad just sitting there, but whatever. Finally got around to disassembling the TV and have the Lamp Ballast removed, but don't know how to test it to find out what's bad on it or if this is the root problem. It was pretty dirty a had to be blown-off with compressed air. I took pictures before and after cleaning. Any help troubleshooting this problem would be greatly appreciated.
rostit
Level 3:
  • Sony Master 746 Answers
  • Posted on Sep 30, 2016
rostit
Sony Master
Level 3:
Answers
746
Questions
0
Helped
202186
Points
2851
You cant test them unfortunately. The only reliable way is to swap it out with a known good ballast. They can and do go bad sitting as the capacitors start to dry out from not using them. Sitting is bad for electronics. Buy a ballast from ebay(used known good) and try it. Thats your best bet honestly.
5 Related Answers
Bill Heronemus
  • 308 Answers
  • Posted on Jan 18, 2007
SOURCE: my sony tv will not stay on
If you replace the lamp and need to reset the Lamp Timer Reset procedure is: With The Set In Standby Press Display, 5, Vol Up, Power on the remote control Press Jump 3. Or, To Display The Lamp Time Press 2 Nine Times. To Reset Press 3, Mute, Enter. One of these should work on your model. Make sure you replace the bulb first. There is a possibility that the ballast could be damaged by a defective bulb as well.
Anonymous
  • 934 Answers
  • Posted on Apr 26, 2008
SOURCE: sony dead !!!!
Jedi,
Sounds like lamp and driver need to be replaced again... Lamp is Sony p/n# A-1052-675-B and the driver p/n# 1-468-798-14
Bill
Anonymous
  • 320 Answers
  • Posted on Oct 18, 2008
SOURCE: sony KDF-42WE655
Bad lamp and/or lamp driver. Try replacing the lamp first.
Anonymous
  • Posted on Oct 01, 2009
SOURCE: Sony Wega kdf-55wf655 rear projection set keeps turning on and off
Had exact same problem with my KDF-55WF655 and put in new projection bulb assembly and no more cut out plus picture is much brighter even on standard. Next time will just by bulb and install in old assembly as it looks straight forward now that I know what assembly looks like. Got about 7200 hrs. out of OE projection lamp and almost 4 years service.
Jason Johnson
  • 1619 Answers
  • Posted on Apr 17, 2010
SOURCE: sony tv model kdf 50e2000 shuts off and red light blinks 3 times.
You need to open up set and clean out all fans of dust or the new bulb isnt being cooled, or the color lcd isnt being cooled shutting TV off.
I've got a Sony Wega KDF-55E2000 there was an
replace teh lamp its might have exploded if its okey check the power supply board but most likely the lamp needs replacement
3helpful
TV Model: Sony Wega KDF-55E2000 Projection lamp warning is on..and today a light red bar appeared at the top of the screen and light blue on the bottom..is this because the projection lamp needs to be...
Hello
There are two possibilities for this fault with Sony Projection tVs. The first is with the lamp itself. The second one is with the lamp ballast baord. Replace the lamp ballast board first. Because, it there is any internal winding short in the inverter transformar of the ballast board this type of fault can occur. you have to replace the ballast baord along with the new lamp anyway. Therefore, replace the ballast board first. If this help you, there is no need ot replace the lamp. Picture of the ballast included here for you to compare.
gopakumarg43_36.jpg If replacing the ballast dis not help you, change the lamp too. OK.
1helpful
Sony lcd projection tv (kdf-60wf655) Tv lamp turns off after 30 secs then come back on over and over ,Green light is solid when lamp is on and blinks green when the lamp goes off. Only when I turn off the...
The board that call the Ballast board might dead,require replacing.This Ballast board only job are to ignite the tv projection lamp.The tv projection lamp been inside the tv like 1 1/2 or 2 years already?Yes.Tv used it everyday like 4 or 5 hrs daily?Yes,the tv should be replacing it projection lamp too.Tv projection lamp life are ending too.
2helpful
I have a Sony kdf55wf655, just replaced the lamp, acts like it wants to turn on then clicks. and still on standby mode. It will blink 3 times pause then blink 3 more time. Did I get a bad lamp? or what...
Ur hear alots clicking,but no picture come on?Yes,than the tv Ballast board is also dead.This tv Ballast board,job is to help to ignite the tv projection lamp.Tries websites like Partstore.com,Ebay.com to buy a new tv Ballast board for the replacement.
I have a Sony Grand Wega KDF-55XS955 and replaced the buld in December of 2009. I turned the TV one the other day and after about 60 seconds, the lamp light flashs red. There's no sequence to the flashing,...
Yes,if "LAMP" LED light indication front bazel panel,flashes or stay on.The projection lamp life is over.Require changing a new projection lamp.But if u also hearing clickings sound too?The board call Ballast board also dead.This Ballast board help to ignite the projection lamp.If a power supply board problems,only power light LED indication will flashes.
How do you replace the projection lammp?
I will forward a link to a page where you can find the instructions on replacing the lamp of the TV.
http://www.docs.sony.com/release/KDF42-46-50-55E2000.pdf
8helpful
2answers
Sony kdf-55e2000 tv
This indicates problems with the image engine. (Lamp does not control the colour). If the TV has not been cleaned recently, excessive dust build up internally may have overheated the image engine. If Sony will not cover it, you might want to consider a new TV.
3answers
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
