Refrigerators Logo
J
Jay Hulet Posted on Aug 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced freezer gaskets now not sealing well
I replaced the door seals of my fridge/freezer. Now the freezer is getting icicles in front top of freezer (frozen condensation?
L Pfaff
Level 3:
Top Expert:
  • Refrigerators Master 11,573 Answers
  • Posted on Aug 20, 2016
L Pfaff
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3583926
Points
181713
Jay, Check to see if hinge can be adjusted so door closes tighter, may be a faulty door seal, or maybe it needs manipulated to soften, shape, stretch it to seal better. You can try the dollar bill trick between the seal and fridge to locate the problem/leaking spots. The bill should not pull out with out there being a little force, no force means seal is not proper in that area. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Check The Seal On Your Fridge And Oven
How To Test And Replace Bad Refrigerator Gasket
How to Fix Gaps in Refrigerator Door Gasket
How to Check Freezer Door Seal DoItYourself com
Hunting for door gasket/seal replacement.
get to a refrigeration and airconditioning parts supplies near you. they'll order the gasket for you. thanks.
I have a Frigidaire freezer that is about 5 years old. I get ice build up inside the top of the door. The door appears to be closed.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
1.) Due you have the freezer in your garage? Freezers and refrigerators are not designed for the drastic temperature change through the seasons. If you had a service contract, your contract would be canceled.
2.) If you can run a piece of paper between the top door gasket and the freezer body you do not have a tight seal. Repair - Recondition the gasket. Wet the door gasket with water, with a hairy dryer heat the gasket while genteelly pulling the gasket out to expand with a spatula.
3.) If the gasket is good, then you are getting moisture either thru the top front of the unit or the top of the door.
a.) Inspect the liner where the ice build-up is. Are there cracks? Repair - Seal cracks with a good silicone adhesive.
b.) Inspect the upper door section and the front top of the freezer for possible leaks in the joints. Here again seal with adhesive.
c.) If the top of the door is expanded, then you have moisture in the door and need to replace the door. You will never get the moisture out of the insulating material.
Icicles in the freezer and frost inside door of freezer. Normal for brand new refrigerator?
It sounds like the seal isn't closing completely. If there is any gap around the seal air is probably entering and the moisture is freezing. This sometimes happens when the doors are reversed. Try heating the gasket with a hair dryer if there are gaps in the gasket.
How to find out if there is a leak on the top of the freezer compartment of my whirlpool french door fridge there seems to be an icicle ?????
Most likely your freezer door or fridge door is not closing properly. Poor rubber seal (door gasket)???
Most likely moist room air gets inside through a door leak
2helpful
Icicles in freezer compartment
you can do the dollar check to see if indeed the gasket is the problem,thats what it sounds like. close dollar in door and pull out slowly,you should feel some resistance.also at the top corner of door you will find 3 screws at the hinge, loosen the screws a couple of turns and you will be able to adjust the fit of the door ,move it alittle to make sure it is square with the fridge,this may help then re-tighten screws.
1helpful
3answers
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
1helpful
Icicles forming from melting ice from ice maker
hi this might help you:
*make sure that the seal indeed still seal well enough...
*the older the fridge the more common this is
i don't really know much about this, but just check that it's cold enough inside like check if it changes when you change it from eg 4 to 7, and that the sealing is fine, and that your door is lined out good, also important that last thing offcourse, cause if it seems to shut good, but the seals arent in the right position compared to the other side (the 'fridge-walls' :p) they won't seal ofcourse...
I hope this is useful, and greets.
I always have icicles in the freezer and anytime we close one of the doors the other comes open and then closes again
Door gasket defective, check for proper seal around door (gasket should be flush against frame when door closed). Also other possible cause is that when you close the door to the ref, the freezer pops open just enough to cause ice to build up around door. Check drain plug inside evap area of freezer, and repalce door gaskets.
1helpful
HOW HARD IS IT TO CHANGE OUT THE DOOR SEAL GASKETS ON MAYTAG FRIDGE/FREEZERS? MINE NEVER SEALED RIGHT AND NOW I AM GETTING ICE CONDENSATION IN THE FREEZER AND DRIPS ON THE FRIDGE TOP. MODEL # MTB2456DEW
Hello, Its not that hard to change a gasket..If you peel the gasket to one side underneath you should see the screws holding it in place...remove all the screws and put the new one in place...Once the new gasket is in place it's not going to seal right so here is a tip...get a heat gun or hairdryer and close the door of the freezer...warm gasket up until you see the gaps close..once you see it has a good seal you are all set. Good Luck!!! Mike
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
