Televison & Video Logo
m
maryke smith Posted on Aug 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i hook up my dvd player to my viera tv
Electro Med Services
Level 3:
  • Panasonic Master 6,694 Answers
  • Posted on Aug 22, 2016
Panasonic Master
Level 3:
Answers
6694
Questions
Helped
1870139
Points
21433
Check the video https://m.youtube.com/watch?v=1Q8EgvpbNjM
if you wish to get some more details then check the link below
http://electro-medical.blogspot.com/
Color distortion when playing DVDs
If the player has other outputs try connecting the player to the tv using one of them, ie: use the A/V output instead of HDMI from the player. If the problem goes away there is something wrong with the input on the tv.
My Panasonic viera TX-26LXD70 says that there is no DVB service found and to check my aeriel or Local DVB service availability. There is no socket to put the co-axial cable in the tv. The tv still works...
Use HDMI from the DVD player and hook up the antenna to the TV..... or DB9 connector on TV.... DO NOT watch DVD from a D VD player or compost cable from the DVD it looks like junk. consult manuel how to hook up your TV
How do i connect my dvd player?
Hello
What is the Brand Name and Model Number of your DVD player which you want to connect with your Viera?
My TV doesn't recognize my dvd player. The TV is new-panasonic viera TCP42GT25. The dvd player is a toshiba-less than a year old.
you shuld check the cable you are connecting. may be there is some fault that is restraining it from recognizing. if the cable is ok check whether the connections made are ok or not. if that too is perfect check for the connecting sockets. check in tv as well as dvd player. change the faulty socket. hope your problem will be solved.
1helpful
We have a magnavox dvd/vcr player. We can't figure out how to record a program from our t.v. on the vcr. it is hooked up to a panasonic viera.
First, make sure the wiring is ok, any outside cable connection (box) wire from the out..should be plugged into the in on the dvd.vcr... and the wire out from the dvd.vcr to the tv...... now make sure the tv and dvd/vcr is both on Ch 3...........(if cable / sat this will select the ch)..... ok test it pick a channel.........press rec on the vcr,,, 30 seconds is long enough... stop rewind press play ..... yeeay.........
I am trying to connect my DMR E55 DVD recorder to my Viera 32LX TV and take the satellite signal from the TV and the recorder is reading nothing. I am using optical cable and a SCART. What am I doing...
To hook up you need to go from the satellite box to the recorder then to the TV. If you do that then you should be able to record the show on Tv. You can get the manual on the link below. Page 7 tells you how to hook up.
http://www.hollywoodstudiorentals.com/uploads/030708__Panasonic_-_DMR-E55%5B1%5D.pdf
Ps3 hookup to panasonic plasma viera
Actually if you do have a ps2 you don`t really need a Dvd upconverter because Ps3 is a full Dvd player +blu Ray Hi Definition.I suggest to take the dvd out and just use the ps3 as a Dvd player
Good Luck
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
