I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Thanks for using FixYa.
Unfortunately,
Coby is a company whose electronics cannot be controlled by any remote
other than the one that came with it. This means there is no code
available for universal remotes. If you need a replacement remote (it
will be identical to the one that came with the unit) please call our
customer service number above. They will take your information and
provide you with the procedure for ordering a part from Coby.
If
you feel this solution doesn't deserve a good rating, please let me
know why so that I may better assist you. If there is anything more I
can do to help, I will!
With remote control and player stopped,
press setup, vol+, vol-, vol+, vol- Use arrow keys to select region 1-6 or 255 for all region.
Numbers appear on TV screen.
Press setup again to save and exit
DVD206 1. Press “Setup” 2. Press Vol +, Vol-, Vol +, Vol -, 3. Number shows up 4. Change the region code by using RIGHT arrow. 5. Press “Setup” to exit.
COBY DVD-514 power on, open disk tray (leave open, closed with no disk in might work too, didn't try), with remote press SETUP, them VOL+ VOL- VOL+ VOL-. On the top right side of the screen your region code will appear, use the left and right nav keys on the remote to switch between regions, and 255 (there is no 0) for all regions
power up. put disc in tray press set up then vol+ vol- vol+ vol- code appears in top right 1 change altering left and right buttons leave on 255 multi region (all discs) press set up.
Coby DVD-514M
Turn unit on with remote NO DVD in the tray (mine was closed, but opened might work) Press TITLE then 1 then 9 Gray box will appear in the center of the screen with number 1 in the middle Using up/down arrows change to desired region (0 for REGION FREE)
