Dec 29, 2015 - Determine which pairing process your device employs. ... Let's say you want to pair your phone with your car's infotainment system so you ..... If your tabletdoesn't come with built-in Bluetooth (and it looks like most, if not all, ...
Dec 29, 2015 - Let's say you want to pair your phone with your car's infotainment system so you can .... i factory reset my tablet and now it wont find my bluetoothspeaker to pair! .... It doesn't look like you can revert to the previous firmware ...
Windows PhoneRead the Bluetooth FAQ for Windows Phone and get answers to common ... You can pair your phone with a variety of devices that use Bluetooth, such as the hands-free system in your car, headsets, speakers, ... Where can I find it? .... ?My phone doesn't reconnect to the Bluetooth hands-free system when I get in my car.
<span><span>Connecting a Bluetooth headset or car kit</span>
<span>
You can listen to
music over a Bluetooth stereo headset, or have hands-free conversations
using a compatible Bluetooth headset or car kit.
It's the same procedure to set up stereo audio and hands-free.
<ul>
<li>For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile. </li>
<li>Before
you connect your headset, you need to make it discoverable so your
phone can find it. You can find out how to do this by referring to your
headset manual. </li></ul>
<ol>
<li>
<span>From the Home screen, press <span>MENU</span>, and then tap <span><span>Settings</span> > <span>Wireless & networks</span></span>. </span>
</li>
<li>
<span>Tap <span>Bluetooth settings</span>. </span>
</li>
<li>
<span>If the <span>Bluetooth</span> check box is not selected, select it to turn Bluetooth on. </span>
</li>
<li>
<span>Make sure that the headset is discoverable. </span>
</li>
<li>
<span>Tap <span>Scan for devices</span>. </span>
Your phone will start to scan for Bluetooth devices within range.
</li>
<li>
<span>When you see the name of your headset displayed in the <span>Bluetooth devices </span>section, tap the name. </span>
Your phone then automatically tries to pair with the headset.
</li>
<li>
<span>If automatic pairing fails, enter the passcode supplied with your headset. </span>
</li></ol>
The pairing and connection status is displayed below the hands-free headset or car kit name in the <span>Bluetooth devices</span> section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car
kit you have connected, you can then start using the headset or car kit
to listen to music and/or make and receive phone calls.
</span></span>
Hi, I had trouble connecting to a corsa with my Nokia, I Had to try serveral things to get it working. first of all is you phone bluetooth name visible?, is your bluetooth name different from other bluetooth device names stored on the car?
Have you tried a bluetooth search from the car to the phone and from the phone to the car?, did either or both devices ask for a pin number(usually 0000)? If you can offer anymore more infomation that would be great.
You can listen to
Before
headset manual.
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Tap Bluetooth settings.
If the Bluetooth check box is not selected, select it to turn Bluetooth on.
Tap Scan for devices.
When you see the name of your headset displayed in the Bluetooth devices section, tap the name.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices
You can listen to
Before
headset manual.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon
i checked that your phone is compatible wd the parrot handsfree bluetooth.
turn-on your bluetooth of your phone
turn on bluetooth of your parrot handsfree see manual where the buton is located
From the phone: * Go to MENU / SETTINGS / CONNECTIVITY / BLUETOOTH / MY DEVICES / NEW DEVICE * Phone will search for available bluetooth devices * Select Parrot Product from the list * Enter Passcode "1234" and go to OK * Accept the pop-up * Devices are now paired and connected
Sending contacts via Bluetooth
If your car has the Bluetooth phone option fitted (most models with the touch screen 2006 onwards do) You may get the message SIG instead of Phone connected.
Go into the information /Nav Screen and you will find an icon for phone, then settings. Click on the icon and it it will give you a connect new phone option, click on that icon and it will release a 4 digit entry code and be findable by your phone. Next go to your phones tools or connections settings and look for Bluetooth, enbale Bluetooth, Search Bluetooth Devices/handsfree Your phone will search out the car, once found it will request the 4 digit pin code to be input and ask you to confirm "handfsree" Once confirmed the car will read out connecting...then bluetooth connection successful and the dial pad will appear on the NAV screen If you have more than one phone connected to the car the driver will need to select the connect phone button in order to chose the phone he wishes to enable
