Cell Phones Logo
varun kumar Posted on Aug 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My number is showing proactive sim command error? what is d soliution
Marvin
Level 3:
Top Expert:
  • Cell Phones Master 85,242 Answers
  • Posted on Aug 19, 2016
Marvin
Cell Phones Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29016733
Points
266281
You could have a defective SIM card, try that first.
2helpful
What is proactive sim command rejected by me ?
This means you may need a new sim card, or there is something wrong with the slot you put the sim card into. Take the phone in to T-mobile and have them check it for you. You may just need a new sim card. Worst case, your phone is failing/failed.
Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so I am here to help you. If your Blackberry 8100 shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Blackberry 8100 . To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
1)Go to Options>status
2)Find IMEI on the back of your mobile, behind the battery.
3)Type *#06# and press call button. It will display your IMEI number.
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site WickedUnlock.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Insert sim
What is your problem with your Sim card? Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so i am here to help you. If your Samsung shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Samsung B5310. To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Theunlockarena.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Insert sim card
What is your problem with your Sim card? Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so i am here to help you. If your Samsung SGH-E840 shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Samsung SGH-E840. To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Mobileunlocksolutions.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
Insert sim card
What is your problem with your Sim card? Is your phone shows the "No Sim" or "Insert Sim" or "Sim Rejected" or "Invalid Sim" error? If it is so i am here to help you. If your Samsung shows the "No Sim" or "Insert Sim" error then remove your Sim from your mobile and place it again correctly. If your mobile shows the error message "Invalid Sim" or "Sim Rejected" the your phone is locked to a particular network. To fix this problem you need to unlock it. Use unlock code to unlock your Samsung . To get the code you have to submit network provider, country and IMEI number of the mobile. Make sure yourself whether you have knew the network provider to which your mobile is locked, country to which the locked network belongs to and IMEI number of your mobile. If not you can find the IMEI number in two ways:
You can find the network provider to which your mobile is currently locked by switch off your mobile and switch on it again. A logo of the locked network will get displayed on your mobile screen. After knew all these get the code from the site Wickedunlock.com ,by submitting these to them. Unlock it yourself using unlocking instructions which is given in the site itself.
2answers
1helpful
2answers
Dear sir i hav sch-M369 & i cant use net services on my cell fone. plz give me ur soliution plz
Try the following Check whether your service provider supports this service or not and the service active on number If Yes
Go to settings>web settings>select your service providers name and activate....
Check whether service providers Access point is active or not(contact the customer care of your service provider for access point setting)
Thank You
Don't Forget To Rate
TATA CDMA 1XUSB MODEM NOT WORKING
Just learnt that Windows has a Hyperterminal through which you can send commands to the USB devices. But the problem is the call centers will not tell the MIN. They just ask to bring the product to their place, which is not possible for a self-employed person. You can change the MIN using the Hyperterminal if you know the value to be entered.
One solution is to read the data using the AT commands from a friends' MODEM and write the same using AT command to your MODEM. This should work if your friend is in the same area as you are in.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
