The console keeps freezing during the opening screen, and the time or two I was able to get past that screen, it freezes when the game is loading. Plus I have gotten the red ring a couple of times. What can I do?
Jason
Clearing your Xbox 360 Hard Drive cache
I've
had this problem myself whilst playing Oblivion, although it was not
only freezing in some places but also being very unresponsive and
really slowing down when trying to talk to NPCs. Anyway, clearing the
cache on your Xbox 360 is very safe and does not affect any of your
game saves, profiles, demos, videos, etc (although it does delete some
downloaded game auto-updates, which will be easy to download again
afterwards). It is mainly temporary data that is stored in order to
make certain areas of games load faster. These can sometimes corrupt,
making your Xbox struggle when trying to read them and eventually just
freezing up.
To clear your Xbox 360 cache you need to do the following:
"a.
Locate the System section of the Xbox 360 Dashboard. b. Select Memory,
select Hard Drive, and then press Y to view the device options
screen.c. On the Xbox 360 Controller, press the X button, press the X
button again, press the left bumper, press the right bumper, press the
X button, and then press the X button again.d. You will be prompted to
confirm system maintenance, select Yes by pressing A."Source: http://support.microsoft.com/kb/907586/en-us
Get a PS3 people... I had same probs and still do! Another problem i had is the discs getting scored( scratched ) to the point they were unusable.
Hey gyz i have been fixing these errors for a little bit now and i recomend this:
first of you will need a t8 and t10 torx driver and some thermo paste i recomend using arctic 5 or whatever they call it
you can get instructions on youtube on how to open your console
1. open your console
2. unscrew *********** board from the alloy box and take out the dvd drive the fan and the small curcit board from the front.
unclip the xclamps from the board and take the heat sinks off and bend the x clamps back a LITTLE bit so they sit tighter
3 remove the old thermo paste and replace with the new stuff you wont need much
them put your heat sinks back on and replace the xclamps
put every thing back in the alloy box and plug in but dont plug in the fan
4 plug your xbox in and turn on you should see 3 red lights let it warm up should take bout 5-10 mins untill you see 2 red lights then UNPLUGthe console from the back
5 when it has cooled a bit plug your fan in and but it all back together and it should work
if you get stuck shoot me an email to [email protected]
thanks i hope this helps yas
I have had this problem also. I fixed the x clamps, cleaned the laser, and I keep my xbox console open to keep it cool. Most of the time I will be in the middle of a game and it freezes. Other times when it is trying to load the game in the beginning. I tried downloading the game to my hard drive also. When playing from the hard drive it again says "unreadable disk". How is that possible when it's not even reading the disk and is playing from the hard drive???
Very frustrating. please help!
Hi radz_01,
Your system is experiencing a 'general hardware error' and is destined to die very soon.
You should try the X-Clamp replacement fix (tutorials available on x-box scene) or you could try my own fix...
www.modelshop.4t.com
Click on News..
If you are still in warranty however, send it back to Microsoft and they should either replace or repair the console for free
*ChaHee* - What do you mean by 'lags' more explanation is needed here!
Buy a new one :)
Ok, basically my problem is the same thing. It keeps freezing up after about 10 minutes of playing even when i have a fan next to it. I havent gotten the red lights yet but im pretty sure theyre right around the corner. What the heck am i supposed to do...
A very common problem which is caused by overheating, well at least overheating is the trigger for it.
The real problem though is what damage the overheating has caused internally, i.e. it could be that the solder connecting the circuitary has melted causing a disconnection.
It's not the only cause though and you can find out more by going to:
www.xbox360keepsfreezing.com
You can also check out a cool song about the red ring of death, heavy metal style :-)
I'm getting the same exact problem, i tried unplugging everything and leaving the xbox in a cool spot for a couple of days, and came back and now it wont even load into the xbox360 system thing, it just gets stuck during the intro =(
Try keeping your power brick cool. I do that by placing it on the corner of my shoe box. I did that and I had no problems.
Try turning off the VSYNC in the graphic options.
Ive heard this alot about ROD my friend did this thing called "the towel treatment" you heat up the system with some towels and it goes away if its only one ring, might not work about 50% chance of it working the other 50% it dies or gets another ring
When i put my hardrive in my xbox 360 it gets frozen on the starting screen and when i take the hardrive out my x box 360 is working fine and perfect but i can't save then idk what to do get a new memory??? but i don't want to lose the old one... help me with this problem thanks :)
My xbox360 keeps freezing when i try to load my gamer profile. what can i do?
The ROD is a serious problem. When i had it i just sent the xbox back to microsoft, and they sent me back an Elite System, but with my old hard drive, so i could keep the memory. When i sent in my Premium console i got it back 8 days later and everything worked fine.
Then when i gave my premium console a try again, as i had not used it since before i sent it back in for the elite, the ROD was gone. I had assumed they had repaired it. Playing offline was fine, no problems, so i gave it to my step-brother and kept the elite, obviously he had to buy his own hard drive as it only came with a 512 MB memory card, and when he got xbox live the moment he attempted to connect to the internet the whole screen locked up. We tried shutting down the TV and unplugging and everything, but it just would not work. We shut off the xbox, playing offline was fine, but as soon as he connected to live, it would freeze.
The next day he signed on to live in the morning, and it worked. Then he came to mine and we used my xbox. When he went home, he started up his xbox again, and attempted to connect the internet, and it froze up. The next day he connected to the internet once, and the moment his xbox was shut down, whenever he tried until the next day, it would freeze up. He could only access live once per day, and he needs to get to the bottom of the problem!!!
If anyone can help please get in contact....
BUT whenever you get the ROD just send it back to microsoft, i got my console back as it was, with a 512mb memory card, a new elite with my old hard drive, so i kept my memory!!!
My problems with the ROD were sorted but i think he would rather have had the ROD because now his console just freezes up!
I know this sounds pretty basic, but I unplugged everything out of my Xbox 360, put it on my windowsill and opened my window, in a few hours i was back to gaming!
every time it's loading anything it lags, I puss that system key and exit out and it speeds up some but still lags.
when i put the game in it loads and im playing madden 07 and 08 or anygame and i do a couple of plays it freezes on me and i got to turn it off and start over
it freezes. duh?
play 2 min freezes up
my xbox 360 keeps on freezing
I've had my Xbox 360 for almost a year and a half and today it freezes when I play for about 2 minutes. It does it on and off-line with Xbox live. I played COD4 yesterday and it worked fine. Today....it freezes! What gives?
i bought my 360 4months ago and has been fine until recently but it freezes after a few minutes
my xbox keeps freezing after I have started the game.the game is not freezing the xbox is because it makes a beeping sound after.
it freezes when i load spcific games
i have the "old" virsion of the xbox 360. i get the red rings of death every once in a while but i fix that but what i cant fix without sending it in is when the screen goes glitchy and it freezes. what the hell do i do?
I just got LEGO Indiana Jones: The Original Adventures and I've beat
story, so I'm going back to get all the "artifacts" (minikit if you
know LEGO Star Wars).
And
I go to one level on Free Play and every single time it freezes, I just
got another copy of the Game and I have the same problem, again, again,
and again. But I can play my other games just fine. Please help.
Thanks,
Colin (GT: udienow103)
My 360 keeps on freezing when i get the games but not the menu and if i turn it on right away it gets the three red lights.
im exactly the same.. if you find a way to fiz it please post it on here
well my xbox 360 the frist time you start it you might be able to get to about 5 minutes into the game but then it just freezes i turned it back on and off and it would freeze at the start up screen the ill turn off and on AGAIN and then three non blinking red lights come up
some one plzzzzzzzzzzz help me ill be so greatful
yeahhh man i have the saaaaaaame problem!!!!!! i get in the game then when ever its loading ,,, it might get passed some points but it will eventually freezZee!!! its driving me nuts !!! what can i doooooo!!!! and its been with me for only 5 monthes!!! i need a quick solution !!!
yea same ere i freeze at the start screen, or when the game is loading or a minute or two into an actual game its so lame wats da cure
my xbox 360 freezes when i start playing about 2-3 mins into it, i have recieved the 3 rings of a death an a frozen screen which says hardware failure please consult microsoft
my console keeps freezing and i dont no what to do
i get to the loading screen and it freezes before it gets to the main menu and the few games it gets past the menu it freezes during gameplay and it is pissing me off
My X box 360 keeps freezing, it either freezes or overheats no matter what game i play and its less than 2 years old and i payed like 500.00 for it thats a bad hit.
I just got fable 2 and every time i turn on the xbox 360 guess what it freezes !!!!
And i just fixed the red lights. Its driving me insane!!!!!
every time the xbox logo is in rite side of my screen on the start up it goes to a blue checkerboard all on my tv it pisses me off
ever since that new update seems i cant get games to load? only a couple times,, and i got the exact problem you do
Same here... I just downloaded the update and now my game keeps freezing and I keep losing stuff I have done. I just bought the system 2 weeks ago.
my console beeps then the screen or game freezes what is wrong with it?
mine just freezes
yeah mine loads everything start a arcade game or load a game it keeps freezing this happend the same atime last year i am so annoyed
freezing up for me
3 red lights
playing a game and the screen froze turned on the xbox again and had 1 red light!
freezing up help!
1 red light
1 red lights
blank screen
red lights
freezing up on me
freezing up
mine will turn on and it will last about 2 seconds before turning on, i dont have the red ring because its not lighting up but its happening almost instantly
my xbox keeps freezing whne i paly need for speed undercover and its pissing me of to the max what can i doooooooooÂ
arghhhhhhhhhhhhhhhhhhh
me too
when xbox turns on it freezes almost instatnly. and if it gets to game it freezes there too
me too, except from its when i put cod 5 in it freezes when it starts up, the grafics dodge up and freezes, and after a couple of times it gets red rings and i know its not the disk cos av tried it on my m8 elite. HELP and i got it on christmas day 2007 and broke on christmas day 2008
every time i put in mortal kombat vs. dc universe it freezes. the game works on my bros box but not mine. the game is brand new
i have the exact same problem
my xbox 360 got the red ring alot but now the game wont even load before the game starts
mine is the same i have gotten the red ring every now and then and it freezes at the start screen the dash bored and in game
My xbox is just off the frits. Some times i freeze at the main menu and somethimes when i am in a regular match and sometimes when its loading. One time I go just one red light and i couldnt even start. So then i unplugged my hard drive and all of my power supplies from eachother. It got rid of the red light but it still freezes. If some one knows what the problem is that would be great
Alex
before anything comes on the screen my xbox just freezes and stays like that and i cant get past it
Best link to solve this problem in less than 30 minutes:http://xboxinstructions.blogspot.com/
Solution Link . . . www.MicrosoftXbox360Console.com`
