You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Here is the long answer with everything we learned while using a power washer twice a day for years:: It covers the things you already tested, but doesn't hurt to repeat. Your problem is actually #8 on list below.
It sounds like could be one of the problems listed below or a combination of those things. 1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day. 2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas. 3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine. 4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or machine would die. We still use machine at 2/3 throttle, and then start each time using WD-40 as described below. 5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists. 6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty 7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week. Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed. Once it starts, keep spraying WD-40 directly into carburetor to keep engine going. If engine will not fire on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal. If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle, and then start it each time using WD-40 as described below.
Now the nitty gritty of starting that bad boy and making you happy again!!!!
If engine will not fire and keep going on WD-40, then your spark is suspect. If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
Karcher Model G2650 OH with Honda 6.0 HP, GC 190 Engine. Engine won't start. New gas, has spark. Seems to flood instantly. Much gas in cylinder. Spark plug wet. Choke pulled out, power on. Oil OK. released pressure in line. Where can I down load a Honda Engine manual! Thank you !
well did u shut water off to take pressure off if you did that it could possibly be a siezed motor you can take wd 40 and put plenty in spark plug hole and let sit over night and if you can pull it then change oil then try starting
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
Buy a new plug, drain out all of the old gas and put in new gas, and take a look at the air cleaner. If the air cleaner is dirty replace it. There you now have a good spark, good fuel and good air. The engine should start. If it doesn't get some carberator cleaner spray and some starting fluid spray.
The problem is the plastic float in the carburetor, it's not adjustable and after sitting up with gas in it it distorts. Save yourself the trouble and buy a new one, you can get them online for $15-$20.
