EDA 1500 is the particular Ericsson's T-series switch and I wish to know: (a) The type of console cable used to connect the said switch to PC. (b) How to manage or configure the switch using the needed console cable to open the RJ45 ports to make it a normal switch. REASON: Because when I connect the LAN cables to the RJ45 ports on the switch it seems not to have any connectivity and therefore no internet access.
(1) Console cable if you have desktop
http://www.instructables.com/id/Simple-RJ45-DB9-Cisco-console-cable/
For laptop console to serial cable
http://d32plhejlomyli.cloudfront.net/catalog/product/cache/6/image/500x500/9df78eab33525d08d6e5fb8d27136e95/1/4/14184.jpg
(b) Reset the switch it will work as a normal switch
skype id [email protected]
SOURCE: configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
SOURCE: Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
SOURCE: DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
SOURCE: PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
SOURCE: No internet on PC when cables going through router
Hello there,
You have to start from the beginning and my solution would be:
1) Remove any connections(also don't forget to turn of wifi on your laptop) to router and except the power cord. With the unit powered ON locate the reset pinhole on the back of router.
2) Press and hold reset button for at least 15 secs. then release, wait for 20-30 secs. before the router can completely rebooted.
3) Configure your Computer IP address to “Obtain an IP address automatically” .
4) Connect internet cable to router on port labeled "WAN". Connect PC to any LAN ports available.
5) Now lets configure wireless router. Open any browser you have (IE, Firefox, Chrome, Safari, etc.). On the address bar type: "192.168.1.1" (without quotes). Default username: admin ; default password: admin click "OK".
6) Go through "SETUP WIZARD" until you reach the "Setup WAN Interface" page. On "WAN Access Type:" select "DHCP" then click next.
7) You may configure your "Basic Wireless Settings" to Public or Private until finished configuring.
8) On "Operation Mode" be sure you operate on "Gateway" mode.
That's it! Hope this helps.
Don't forget to vote.
