Question about NorStar M7310 Corded Phone
Incoming call automatically holds and I have to push line 1 button to connect
I can dial out with no problems and its just on that specific line. phone company troubleshot and narrowed it down to something with pbx or phones.
SOURCE:
SOURCE: No dial tone and also all the lights are flickering, please Help!
Unplug and and plug back the phones and see what happens.
Posted on May 13, 2008
  • 3 Answers
SOURCE: can't make outgoing calls
You have to press a Line to call out. Line 1 or Line 2 or Line 3
Posted on May 22, 2008
cnavarro
  • 2460 Answers
SOURCE: line buttons showing wrong phone lines
When a phone has only 2 lines, it's not programmed. By default, a Nortel system has 2 lines and that's all. Go into system programming and assign the number of lines and intercoms to a phone. After that, you can copy the buttons from a working phone to the new phone and you're done.
Carl
Posted on Jun 22, 2009
  • 18 Answers
SOURCE: Nortel M7310 Phone moved to another jack, now no incoming calls
The reason your phones config is not the same as before is because configuration goes by what extension it is. So if you plug your phone in somewhere else, unless you have DN's configured, your extension changes, so say it was extension 21, but now that you moved it, its now 23, those settings remain on extention 21, so if you bought another phone and plugged it into were extention 21 is, it would have the settings that your old phone had before
To access the intercom by just picking up the handset, Press Feature **CONFIG (266344), Select <A. Configuration>, then go to <2. Line Access>, Select that and enter the extension of the phone you want to have access intercom by just picking up the handset. Scroll until you see <Intercom Keys: #,> make sure you have at least one intercom key. Then scroll until you see <Prime Line: #>, Press change until the display reads <Prime Line:I/C>  And there you go. Hope i didn't confuse you
Posted on Oct 02, 2009
SOURCE: Norstar m7310 needs rls button pushed after every call
I've seen this many times; Check the Handset cable. It is probably plugged into the Headset connection on the phone.
Posted on Jan 04, 2010
I CAN'T SEND FAX WITH EXTENSION NUMBER
Generally if you wanted to send a fax to a facsimile which is connected to an extension.you must dial only the direct line number and ask operator to transfer this call to fax (wanted extension).After you heard the fax tone you can push start button.
If the fax machine full-time connected to same extension & dedicated direct-line there only for faxing,we can program the pbx for automatically transfer the incoming fax or call to that extension.so outsider have to dial only direct fax number without ext no.
Only Panasonic PBXes having a unique feature if i'm wright if it detect fax tone from any direct line it will automatically transfers towards fax extension.
Mar 24, 2014 | Panasonic KX-FL611 Plain Paper Laser Fax
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How to recieve a fax on the Canon PIXMA MX340 Wireless Office All-in-One Printer
Take your incoming phone line and plug it into the place that says "line" on your fax machine. Plug another phone cord into where it says "phone" and connect this to your telephone. Test to make sure you have chosen the right places by dialing a phone number to fax to and listen for the dial tone. If you get a dial tone, then you have set it up correctly.
On the fax machine look for the button that says "menu". Push it and use the up and down arrows to navigate the options on the display. Look for fax set up and press "ok" or "enter" on the fax machines keyboard to access this area. Look for "number of rings" and change the fax machine to a number of rings that is less then your voice mail box if you have one. Then close and save your choices.
Have someone send a test fax by dialing your phone number for the line connected to the machine. The fax machine will pick up on the number of rings set and automatically begin receiving and printing a copy of your incoming fax.
You cannot use magic jack.
You can also choose to manually answer an incoming fax if you see that your display on the fax machine says "ringing" or incoming" you can push the "start" button and this will start receiving your incoming fax.
Sep 30, 2010 | Canon imageCLASS MF7480 Laser Printer
I have a panasonic hybrid phone system and would like to connect a fax machine, when I connect the fax to the jack, I dont get a dialtone but it goes to the intecom line. The same happens if I connect a...
Hello, you can solve this one of two ways. Try pushing a 9 when you get intercom line, you should get an outside line. So when you want to send a fax, just remember to push a 9, get outside dial tone then dial your number. Or, the second option would be to program that extension jack to auto select a line when going off hook. That will take a manual and some additional guidance. Okay, so thats for making outgoing calls. When it comes to incoming calls, you need to find out what extension the fax is connected to. You can do this by dialing another extension that has a display from the fax machine and see what intercom number comes up on the phones display. So once you know the extension number you can do one of two things. You can leave the fax off since it will most likely ring when any call comes in your office, and only turn it on when receiving a fax. When you answer the fax call on one of your other phones, and hear the beep beep beep, merely push transfer and dial the fax machines extension. That will transfer the incoming fax call to that extension and the fax machine provided you have it turned on. The other option is to break out the system manual(not user guide), and program the fax machines extension to only ring on the line you want it to, say your last line and leave the fax machine on and give out that specific number for faxes. But you do run the risk of your call traffic being heavy, incoming calls rolling over to that line or someone calling that number directly and getting the fax. I think I covered everything I can with the limited information on your application, so I hope that solved your problem.
Sep 17, 2009 | Panasonic Advanced Hybrid w/Back-Lit LCD...
I want to push the line button to answer the phone, not just pick up the handset. I have vodavi StarPlus TR 9015
Now that's an oldie but a goodie :-)
Line Preference Incoming (called PREF LINE ANSWER in Vodavi) requires system programming from a 24 button set. It's a sequence of FLASH 50 (your extension twice) and hold, then press Flex key 8 and dial 0 HOLD.
Of course you have to know how to get into system programming and try not to do anything destructive.
Carl
Sep 09, 2009 | Vodavi Lands Phones
Wiring a dayton timer relay
If i understand you correctly you want to push the button, release it and have the timer give power to the solenoid for 3 more seconds, correct? If this is the case you will need an off delay timer. On delay timers work like this. You push the button, power goes through the timer, at this point the timer starts counting, when the timer reaches its preset point,(3 seconds we'll say) the contacts change till the power to the timer goes off.
If you hook this up with an on-delay timer this is what will happen:
Push the button and release, the timer will tick as long as you hold the button down, till three seconds, then the solenoid will raise until you release the button.
With an off delay this will happen: push button , solenoid begins working, when button is released timer counts 3 seconds while solenoid is still working, then removes power to the solenoid.
The way you would wire the off-delay is like this:
Connect line side of your pushbutton(incoming power side),incoming power and terminal 1 on your base together. next connect the load side (outgoing power side) of your pushbutton and terminal 2 on your base together. Connect terminal 3 to the hot wire or terminal on your solenoid. Lastly connect terminal 7 the incoming neutral wire and the neutral wire or terminal of the solenoid together.
I am telling you how to wire it in my head, if you'll write back with some specifics such as what wire you will use, where your getting power from,what the solenoid current draw is and such i can get a little more detailed. maybe it will make more sense.
Also make sure the timer and pushbutton are rated to handle the solenoids running current. The timer appears to handle 10 amps im not sure what you pushbutton can handle. Also keep in mind the solenoid will operate for whatever time u set it to, after the button is released. There are other ways to do it but this would be the most economical way.
And of course turn the breaker off and test that it is off before working on the circuit. Write back with any problems.
Apr 02, 2009 | Amperite Dayton Solid State Timer On Delay...
Forgot password
Performing a Clean Boot
THIS WILL TAKE IT BACK TO THE FACTOR SETTINGS
A clean boot resets the EDA to the factory default settings. All data is the Application folder is retained. You must
download the Clean Boot Package file from the Support Central and install on the EDA.
NOTE When the EDA powers up after inserting a battery for the first time, the device boots and powers on
automatically.
CAUTION A clean boot should only be performed by an authorized system administrator. You must connect the EDA
to AC power during a clean boot.
Removing AC power from the EDA during a clean boot may render the EDA inoperable.
To perform a clean boot:
1. Download the Clean Boot Package from the Support Central web site. Follow the instructions included in the
package for installing the package onto the EDA.
2. Simultaneously press the Power button and the 1 and 9 keys.
3. Immediately, as soon as the device starts to boot and before the splash screen is visible, press and hold the
left scan button for a few seconds.
4. Insert the EDA into a powered cradle.
5. The EDA updates and then re-boots.
6. Calibrate the screen.
Waking the EDA
The wakeup conditions define what actions wake up the EDA. These settings are configurable and the factory
default settings shown in Table 1-3 are subject to change/update.
Table 1-3 Wakeup Conditions (Default Settings)
Status Description Conditions for Wakeup
Power Off
(Suspend Mode)
When the EDA suspends by pressing
Power, these actions wake the EDA.
1. Power button is pressed.
2. AC power added or removed.
3. Cradle/cable connect or disconnect.
Key or scan button is pressed.
Real Time Clock set to wake up.
Incoming phone call (MC7004/94/95 only)
Auto Off When the EDA suspends by an automatic
power-off function, these actions wake the
EDA.
Apr 11, 2008 | Symbol MC70
FAX function stopped working
honestly, it sounds like you have the phone cord and the fax jack swapped backwards, make sure you have the fax line plugged into the correct jack on the machine. 1 is for the handheld phone and the other is for the telephone line... give this a shot...
Mar 10, 2008 | Brother MFC-7220 All-In-One Laser Printer
Phones won't ring
Your memory battery on your telephone system is bad. when power is lost , so is the programming. to fix this , you must go into system programming. From any phone, without picking up the handset. Press #20 Dial 12341, Press #. Press # again and dial 62, Press Line 1 and then press the button of each stn you want to ring ,( The display will show 1 if you press stn 1 and so on.) program each line the same way.
Nov 19, 2007 | Samsung Prostar 816 Phone
Call managing
Try to see if your phone has a Call divert Feature. 1. You can Divert all voice calls 2. You can Divert if busy 3. Divert if not answered 4. Divert if out of reach 5. Divert if not available
Jul 20, 2007 | Nokia 1100
NorStar M7310 Corded Phone Logo
64 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
