Maytag MAH6700AWW Neptune Front-Load Washer Logo
James Hoag Posted on Aug 18, 2016
How to fix leaking tub
Water leaks directly out of bottom of tub at all settings.
5 Related Answers
Washer_tech
Geoff Siegel
  • 164 Answers
  • Posted on Dec 26, 2007
SOURCE: leaking water from underneath.
sounds like several problems. sounds like your boot stem/ seal is leaking and possibly the tub bearing is rusted. I generally replace both at the same time as long as the machine is apart anyway. As for the squealing and tub slamming to a stop, that is your brake package and bearing have dried and/or rusted and need to be replaced
Anonymous
  • Posted on Aug 20, 2008
SOURCE: maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Anonymous
  • 734 Answers
  • Posted on Dec 12, 2008
SOURCE: My front loader is leaking water from the bottom
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 31, 2008
SOURCE: Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
Anonymous
  • 245 Answers
  • Posted on Apr 30, 2009
SOURCE: My Maytag Neptune leaks water from the bottom (immediately) as it fills with water
usually this is from the front door seal going bad remove the front panel and door to replace it
2answers
There is a leak and we can not find it. Any solutions
This may help?
Fill spa to highest level possible.
Heat to 100 degrees or higher.
Then, with your bare hand feel throughout the bottom rim and anywhere else you are able to: see if you can feel "Warm/Hot" water. Any "Cold" water is not the area of the leak, that water has "Travelled" there. The warmer the water, the closer you are to the origin.
5helpful
Water is running out inside bottom of mechine
  1. Air gap device: It is a small device found on most washers to prevent the wash water from from being siphoned into the household water supply. It is located either midway along or at the the end of the black rubber hose that comes from the water inlet valve It is usually made of a translucent plastic. If it is deformed or cracked, you need to replace it.
  2. The tube: It is a rubber tube that runs between the water inlet valve and either the air-gap or the inlet spout. If it is broken, it can cause a leak.
  3. Inlet spout: Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If broken or loose, it can cause a leak.
During the drain and spin only:
  1. A washer that leaks only during the spin cycle often has a leak in the main drain hose. Check the entire hose and correct any problem you can find.
All the time:
  1. Hot and cold water fill hoses: Check the hot and cold hoses from the household plumbing. If either hose is leaking, tighten or replace it.
  2. Main tub seal: It is located between the transmission and the outer tub. Open the the machine's main access panel while the machine is full of water with a small amount of detergent. The leak appears at the underside of the outer tub, at or near the center.
  3. Pump: You can probably see the leak when the tub is full of water. If it leaks, replace it.
  4. Outer tub: Steel or plastic outer tubs can rust, split or be punctured. Consult a qualified appliance technician if it is the culprit.
1helpful
What is the model number? and year made?
Hose could be loose and leaking. Check and tighten all hoses first if problem persists, check if water valve is leaking. If not check the tub for leaks. If tub is leaking you may not want to fix as this is an expensive problem. If you want to fix use part number and call First Source Parts and as for a Washing Machine Tub.
1helpful
Leaking below washer
Sounds like you have a leak from the tub. Either the seal in the bottom of the tub or a hole in the tub.
When you run it again try feeling around the bottom center of the tub for water or try to see if water is leaking any where out of tub. Clear water would be from the supply line , soapy water would be from tub or a hose coming out of tub.
WATER RUNNING FROM THE BOTTOM OF MY DISHWASHER AFTER THE FIRST CYCLE
Since if did not begin to leak during the DW filling, we can rule out the inlet hose and solenoid valve.
When water leaks from underneath and not from the door, the most common failure is the seal between the DW tub and the wash pump/motor. Replacing that assembly would be the way to repair that problem.
The other possibility is that you have a rusted or broken tub enclosure which is leaking directly through the bottom. Replacing the dishwasher would be your best option then.
Good Luck!
May 07, 2009 • Dishwashers
2answers
Siemens Siwamat 2105 washing machine leaking
During fill only
All the time
During fill only
All the time
1helpful
Water leaking from bottom of front lode washing machine
During fill only
All the time
During fill only
All the time
4helpful
During fill only
All the time
During fill only
All the time
2helpful
3answers
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
20helpful
My Ge washing machine is leaking from the Bottom
During fill only
All the time
During fill only
All the time
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
