Question about Frigidaire FAS256R2A 25,000 BTU Window Air Conditioner with Electronic Controls Full-Function Remote...
My frigidaire AC starts cooling fine but stops blowing cold air after few minutes and it does not cool at all. I haved turned it off and re-started it and it does the same thing
    Top Expert:
  • Frigidaire Master
  • 12,962 Answers
The compressor is being prematurely turned off. That explains why the cooling stops after a few moments. Either the thermostat is responsible or the electronics working with the therm are responsible for the anomaly.
Freon level is fine because it does cool when compressor is running. U might also want to check the start/run capacitor. That sucker starts the motor and keeps it running after the start. If the run section goes bad the motor will usually stop after it starts.
Posted on Aug 17, 2016
  • Kropls Bierhaus
    Kropls Bierhaus Aug 17, 2016
    Thank you richie. Today the AC was working super fine!. It was cooling to 60 without problem. Thanks again.
  • 388 Answers
Check thermostat device it may can faulty need to replace
Testimonial: "Thank you. I will get the part."
SOURCE:
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
My ac is acting funky. my ac will blow cold air as im moving. once i stop and idle for longer than 3 or 4 minutes, something will kick on and then it will start to blow hot air. as this happens, my car...
Start by checking to make sure that the a/c condensor and radiator is not full off debris. If the condensor and radiator were full of debris it will limit the air flow from the engine cooling fan which in tern will cause a high discharge pressure on the discharge on the a/c causing poor or no cooling at idle and could also cause vehicle to overheat. Check and make sure that the cooling fan as well as the condensor fan are coming on together when the a/c is turned on if equipped with 2 fans.
Sep 12, 2013 | 2004 Chevrolet Cavalier
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
'97 Jeep Grand Cherokee AC "Works and Stops"
Make sure your fan clutch is working. No fan, no cooling of the condenser, no heat dissipation, no cold air. Start the truck and make sure you feel air movement, a lot.
Aug 11, 2012 | Jeep Grand Cherokee Cars & Trucks
AC cools then blows hot air, tempature needle goes up & down
Sounds like the thermostat is trying to stick,and is causing the engine to over heat,therefore condenser is not cooling the freon down enough to cool.Have the thermostat changed and the cooling system bled out,this is most likely the cause.
Aug 29, 2009 | 2005 Lincoln LS
Air conditioning not working properly
Would have him check out side air temp sensor ,thermister and rerove control head and inspect for burned terminal.1st.
Jun 20, 2009 | 2002 Oldsmobile Silhouette
Window AC takes spells on cooling?
One thing to check is to make sure the evaporator and condenser coils are clean. Any dirt here will short ccle the compressor.
Aug 23, 2007 | Frigidaire FAS156N1A Air Conditioner
Frigidaire FAS256R2A 25,000 BTU Window Air Conditioner with Electronic Controls Full-Function Remote... Logo
185 people viewed this question
Top Frigidaire Heating & Cooling Experts
Donni Steen
Bill Long
Pete Norton
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
