I NEED TO VIEW WHAT IS ON MY MIRCO SD CARD WHEN I PUT IT IN THE COMPUTER NOT CAMERA WHAT ACCESSORIES DO I NEED TO DO THIS FOR THE COMPUTER TO VIEW WHO HAS BEEN IN MY HOUSE
Re: I NEED TO VIEW WHAT IS ON MY MIRCO SD CARD WHEN I PUT...
Well not many pc's have Micro sd card ports , so id say u need to start there , buy a usb to mirco sd card reader (there less than 20 dollars) and then install the drivers that come with reader , then its all up to windows (assuming you have windows) it should see that u have properly connected the reader and then ask you via a pop up what you would like to do with the new drive, of course u select "view files" depending on what put the files on the card it should be in a directory already (name can be numbers or letters?) click on this and u should see your files or photos on there
Marie, If your computer is not equipped with a SD/Micro SD card Reader you will have to purchase one to simplify looking at it and copying it on computer. You can also use appropriate cable possibly to hook your camera up to computer.
Step 1/ Insert a USB card reader into an available USB port on your PC.
Step 2/ Insert the micro SD card into the card reader. Some card readers will only accept standard SD cards. If that's the case, insert your micro SD card into an SD card adapter and insert the adapter into the card reader.
Step 3/ Click "Open Folder to View Files" in the Auto Play window to launch Windows Explorer in the appropriate drive letter. Alternatively, press "Windows-E" and click the card reader's drive letter.
Step 4/ Drag and drop files to or from the micro SD card's drive letter to copy files. Alternatively, right-click and drag files and then select "Move Here" to move the files without keeping the files in the original location.
Step 5/ Select a file, press "Delete" and select "Yes" to delete files from the micro SD Card.
Step 6/ Right-click the micro SD card's drive letter and select "Eject." Once ejected, you may safely remove the card.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How to Transfer Pictures From MicroSD Card to PC How to use card reader Card Readers Adapters Memory Card Readers
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked). Hope this helps.
Click on the drive and then in windows select tools then folder options, then view and select or unselect hidden files or folders, plus hide protected files.
This should show all files on the card.
The only other thing I can think of is that the camera uses a different format to Windows. So it can't read the card.
This should do it for you: Insert the SD card into your laptop or computer. In the SD card go to "New Folder" name that folder "DCIM" in the "DCIM" folder create a new folder. This one you will name "101KC190" (I'm pretty sure you have the Kodak Easyshare 190, correct?) Now, transfer all of your pictures into "101KC190." Insert the SD into your camera and it should work. email me if you need to [email protected]
Hi if u have a password on the mirco sd card on your phone the password is only only on the phone not the sd, so you can take the card out of the phone. and put it into a mirco SD card to usb adapter
put it into your usb on ur pc and take all the files you want off. then you can do a master reset on your phone to reset all the setting on you phone and then u can put the sd card back into ur phone
You can, just hook your phone up to your computer vie USB cord. When hooked in, open phone go to 9. Settings & Tools then 2. Tools then 9. USB Mass Storagethis will connect the mirco sd card. PC under My Computer>removable drive open you should have folders listed go to My_Music, drag your mp3's to that folder. If using a Mac it needs to be a new Mac to recognize the mirco sd card, do the same steps as above and the mirco sd card will show up on the desktop as a drive. jh3:16
9. USB Mass Storage this will connect the mirco sd card. PC under My
My_Pix, drag your .jps from/to that folder. If using a Mac it needs to be
