Mine is an Invacare M51 Pronto Surestep with an onboard Winsunny battery charger. My charging lights are solid red and green/ yellow. Depending on if it is charging or not. What kind of charger do you have?
I have to replace my charger because it is not working. My green light is staying green while charging even though my joystick is showing my batteries are depleting and I just got new batteries. sigh.
I have the same problem. I watched the video on helix.com and it shows it off while charging, but mine blinks for like 3 hours then turns solid green so I guess it is done. Anyone care to comment???
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
