House is set up with Dishnetwork - was originally set up to view on channel 60 - setup had to be changed to view on channel 73. Cannot change the Westinghouse TV channel.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
(OSD)
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
WHITE WESTINGHOUSE Codes: 097/ 100
Four digit codes for white westinghouse are : 0100 0130 0138 0136 0227 0279 0080
four digit codes for wetinghouse are: 0143 0114
OK
