Phone switched to spanish ...need to go back to english
Without phone model - I can give you vague solution but here goes
find apps. in spanish it will be most likely be aplicaciones
find settings could be Ajustes in Spanish
system - Sistema in Spanish
look for Idioma e introduccion in Spanish
then look for idioma in Spanish
change from Espanol to english
SOURCE: how do i switch my phone from spanish to english.
Go to settings and tools....select 1settings....select 1 display....select 4 Language...then select english
Hope this helped...later
SOURCE: PHONE IS IN SPANISH
If you can make your way to the main menu, select settings, (whatever that may be in spanish, sorry!), then go under languages to select English. I had to have a rep. from the company I have my phone thru to do this for me.
SOURCE: need a LG Black Zafiro manual -- LG-MG810d
I have not found an English version of the MG810D user guide, but the VX8600 is a very similar phone.
See page 75 for the language preference setting and you'll get a feel for how to make the same change on the MG810D.
http://www.lgmobilephones.com/uploadedFiles/LG_Mobile/PhoneAssets/VX8600/VX8600_UG_E.pdf
You'll need to navigate the MG810D to find the following:
Configuración (settings)
Idioma (language)
Inglés (English)
SOURCE: my verizion env2 phone was switched from english
Open the the phone and hit the OK button for the menu
Press 9 which is settings and tools.
Press 6 which is the phone settings.
Pressing 4 will get you the Language selection.
Use the direction pad to
scroll to a ENGLISH, then press OK.
Should be good to go.
Hope this helps,
Bill
SOURCE: MY PHONE CHANGED LANGUAGE FROM ENGLISH TO SPANISH...
All you have to do is start your menu from the begining, in timing advance to the language menu(if possible refer timing with the manual) scroll down and select- Anglais, press ok, there you are.
Hi angela sweet, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
Make and model number. model number should come up on screen when powering up from off condition. Could be under battery inside the phone
