This is backward of most people's problem, but ever since I switched to Frontier for my phone service, my Uniden phone won't blink it's red light at all. I DO get the pulsing dial-tone, just no blink telling me I have messages. I don't think this is related to Frontier, but I can't figure out why it suddenly ignores the dial-tone and won't alert me with the flashing red light.
The pulsing dial tone usually indicates a message on the service provider's server, not on your phone. Contact your provider to find the procedure to access these messages.
Testimonial: "Thanks. Unfortunately, Frontier has awful customer service (I'm learning). The hung up on me after they gave me the wrong information (wrong pdf manual, wrong phone app) multiple times in chat."
SOURCE: voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
SOURCE: The flashing light on phone
SOURCE: can't change to pulse dialing
The Vetech phone will only support tone dialing. It does have a menu option that turns tone on or off but it still will not allow pulse dialing. I had to change the phone service from pulse dialing to tone dialing to get the phones to work. As it turned out, the phone company no longer charges extra for the tone service.
SOURCE: Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
SOURCE: Red message light is blinking on my Uniden phone
hold down the "find handset" button on the phone base until the beeping stops. This will reset the message indicator. I just had this problem and downloaded the manual from uniden.com.
