Cars & Trucks Logo
Rodney Trebilco Posted on Aug 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
L am placing an after market radio into a ford forte au 11 2000 model after pulling out the original radio out l need a wireing diagram for the original harness of 16 wires the new radio has 12 wires
Wireing diagram for harness on original harness to tell what wires are running to what.
bigdawg7299
Level 3:
  • Ford Master 2,559 Answers
  • Posted on Aug 15, 2016
bigdawg7299
Ford Master
Level 3:
Answers
2559
Questions
0
Helped
556220
Points
7776
Http://www.fordaustraliaforums.com/forum/showthread.php?50606-Need-wiring-diagram-for-au-11-ford-2002-for-stereo-please-help
there are two links on the second post.
Im after a wiring diagram for a 2008 Ford E-250 radio/stereo harness, to install a after market radio
use the link for radio diagram https://www.modifiedlife.com/ford-radio-stereo-wiring-diagrams/
How do you pull the radio out of a 1998 ford expedition to get to the GEM?
thats easy the dash panel around radio just pops off with flat head screw driver and 4 bolts hold radio in.however the gem is not behind the radio its behind the fuse block in the dash. in addition if your radio is not working it could be a bad fuse or bad wire .does the radio light up?if so then its not a bad fuse or wire .in witch case check your model xlt eddie baur etc some model have just basic radio other have radio with external amp in the dash behind radio these often go bad it is then up for you to decide to get original equipment to work or install aftermarket radio in some cases after market radio is cheaper and depending on the model you purchase perform better .yah unfortunetly car manufactures install cheap radios in all vehicles wage your options aftermarket radio cd player say sony brand usually around 60$ and shud only take 1 hour to intall hope this helps good luck
I have a 2001 Ford Taurus, just installed a factory stereo/heat control unit back in the car but I have no power to the stereo. What should I check?
I would check the fuses for the radio. One should be in the engine compartment distribution box and there should be another fuse in the interior fuse box. If these fuses are intact and you have a multimeter, I would check the presence of at least 2 pins with + 12 Volt on the radio connector. The pin out diagram can be seen if you do a search for the 2001 Taurus. Good luck, hope this helps.
I have a 92 ford probe and im trying to install a
Have you removed the original connector from you original stereo? If you still have the original connector in place you can get a new connector from the Ford dealer that will plug into your existing wiring and into your new deck. Ford connections are unique to Ford and you need to adapt them for this application.
Take the car and deck to the dealer and tell them what you need. Everything just plugs in and your original amp and speakers in the car will work.
Having said that there was an adapter available at Wal Mart of all places that did work. You may want to check there.
If you have removed the original connector then you need a wiring diagram.
1992 Ford Probe Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Red
Radio Switched 12V+ Wire: Blue/White
Radio Ground Wire: Chassis
Radio Illumination Wire: Light Green/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Orange
Left Front Speaker Wire (-): Blue/Black
Right Front Speaker Wire (+): Blue
Right Front Speaker Wire (-): Blue/Green
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Green/Orange
Left Rear Speaker Wire (-): Green/Red
Right Rear Speaker Wire (+): Green/Blue
Right Rear Speaker Wire (-): Green
The amp is located under the rear passenger side window. You need to remove the plastic side wall to expose it if you need access there. You can trace the wiring if needed.
Under the front bottom edge of the rear seat are clips holding the seat in place. Open the clips and the seat lifts off. You can then get to the amp as needed.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
