Is it better to use VGA instead? Is the monitor useless at this point? how do I make the ps3 compatible to the monitor? Are there any steps I'm missing?
You need to change the resolution on your PS3 to match the 1680x1050 of the monitor:
Start with your PS3 turned off. With the PS3 off (showing a solid Red light) if you hold the power button down until you hear two beeps it will force the PS3 to forget any saved video output settings and boot up at a lower resolution. It will then take you through the Optimal Resolution set up.
