Samsung 43 PN43D450A2D Plasma TV Logo
m
matt Smythe Posted on Aug 15, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a samsung plasma that clicks but won't turn on. After disconnecting and then alternately reconnecting the different boards only the X board causes the clicking sound and no turn on. Is it bad
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Aug 15, 2016
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15005546
Points
237762
Replace it and check. If you wish to get some details; check the site linked here. Pull up older posts.
Testimonial: "went to that site couldn't find any thing relevant"
2answers
I've replaced every board on the samsung plasma and still clicks
What do you mean by clicks? Plasma televisions are hot cathode ray, there is thermal expansion that takes place due to heat.
Samsung plasma won't turn on
Here's is what you need to look for when describing a problem for troubleshooting purposes:
0) What model is the TV (you've covered that)
1) Does the TV respond to command to turn on?
(yes - continue; no - 70% bad power, 30% bad main board)
2) Once it responds (clicks), does a front LED or other indication show that it turns on? It's OK if there's no display.
(that can be model specific and is not certain indication for anything until known what is specific for the model)
3) If such an indication comes up does it remain on until you act or does it go off by itself?
(Stays on - power supply likely good; turns off - power supply *may* be good, but not certain)
4) If the power indication stays on by itself can you make it go off by pressing the power button or do you have to disconnect from AC power?
(responds to power off - 90% power supply likely OK and 90% OK main board; does not respond to power off - 90% bad main board)
Here is a link for test/repair of the power supply of your TV, hope it would help:
http://www.coppelltvrepair.com/p/895/samsung-pn58a550s1fxza-power-supply-repair-service-for-dead-or-clicking-on-and-off-problem
2helpful
I have a Th-50PC77U that doesn't turn on. Relays will click and start to power up but then it goes into safe mode and the power LED blinks 7 times. Is there a circuit board i can replace to fix this?
& blinks is sc or,sd or ,su board or all 3. Disconnect the ac cord. remove the back cover. on the left are 2 thin boards with flat cables that connect to the panel. these 2 boards are the SD and SU boards. They are connected to a board to the right. This the SC board or Y sustain board. Disconnect the 2 wie plug that connects this SC board to the power board in the middle. Examine the sqauare ics on the SC and SU boards on the rt side. Look for a pit or burn mark on one of the ics. If you see one then this board is bad. Disconnect this board from the SC board remove connectors on the rt and also remove the all the screws on this board. It should now be hanging free only by the flat cables on the rt. reconnect the 2 wire cable from the SC board to the power board. Plug in the set and power on. If set turns on the that board needs replaced. You will see 1/2 of picture. If still won,t turn on then disconnect the ac cord and the 2 wire conn from power board to SC board. disconnect the other board on the left letting it hang free. re connect SC to power board,plug ac cord in and turn on. If set now will turn on then Replace that board. If stiil won/t turn replace the SC board.
1helpful
2answers
SAMSUNG PS42Q96HD PLASMA ,16 MONTHS OLD, RED LIGHT COMES ON WHEN STARTED UP BY PUSHING IN THE ON BUTTON, AND BEFORE A NANO SECOND IT THEN TURNS ITSELF OFF, ANY IDEAS PLEASE ANYBODY ????
Could be power board. Check for swollen capacitors . If ok next check buffer boards for burnt ic. With set unplugged unplug power board from sustain boards. Plug back in and see if it turns on. Unplug again and disconnect buffer boards from sus board plug power supply back into sus to see if it powers on. If it does then buffer boards bad. Isolate upper and lower to Determine which one is bad. Just always remember to disconnect power board from sus boards when disconnecting panel to buffers. Power supply stores a lot of energy and will burn these connectors while reconnecting them.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
