Luxor 19822 COB Logo
A
Anonymous Posted on Aug 14, 2016
My luxor model number 42742742tvb wont come off stand by can you give me help
Wont come off stand by can you help
Electro Med Services
Level 3:
  • Luxor Master 6,694 Answers
  • Posted on Aug 21, 2016
Luxor Master
Level 3:
Answers
6694
Questions
Helped
1871100
Points
21433
If you wish to get some details then check the following link
http://electro-medical.blogspot.com/
How turn tv on no remote luxor smart t v
There is no such thing as a cebsor button and I cannot guess what you tried to type. Here is a phone number for Luxor: 1-800-323-4656
https://www.youtube.com/watch?v=CtDh8uihumY
HOW DO I INSTALL AMAZON PRIME VIDEO ON TO MY LUXOR SMART TV
Really need to know the model number of your Luxor.
Please provide.
Semper Fi,
Z
I need a replacement remote control for a Luxor model number 150004/01
if no genuine remotes online anywhere
you could use a desk top digital receiver
and set up the luxor to run through its remote
universal TV remotes will have some functions using the luxor list of codes
Luxor tv reset to factory settings
I have a luxor 32in TV
LUX0132009/01 model. It's been fine but now the volume symbol wont go off the screen which then stops the remote doing anything. Is there a way I can fix this myself?
Thanks
My relative in UK send me a luxor tv here in the philipines..THE SOUND IS OKEY BUT THE PICTURE IS BLUERD..SOMEBODY CAN HELP ME
power voltage drop of 10 volts where you are
The more significant difference is that 60Hz systems usually use 110V (120V) or thereabouts for the domestic power supply, while 50Hz systems tend to use 220V, 230V etc
if found to be the issue and no slide switch to change on the TV somewhere
you may need a converter to equal 60 hrz
sound ok
any luxor should work there
i am thinking local signal signal
cable or roof antenna in the place
if auto auto tune or manual tune wont give a picture
not sure if a converter is needed
i am thinking try
. if coax cable old
re do all connections or replace with new cable
could get a TV antenna guy to reset the roof direction signal
if no better ..have doubts but
different channel wave lengths or faulty signal receiver
does the user manual cover world wide distribution or support
information
no online luxor TV support contact number
just a wiki information link
a long phone number ???
the internet email address is looping [email protected]
http://luxorhelp.com/luxorhelp/wiki/index.php?title=Tech_Support
We plug the laptop to the tele using the HDMI cable, the tele doesn't give us any sound. We tried it on other tele and its working so its something wrong with the Luxor tele.
Ok, sounds like you know what the problem is. So what's the question? The only possibility I can think of that wouldn't require repairs to the set would be if there was an option for selection of digital optical audio and that were selected instead of the HDMI audio input. Without the model number of the set, I cannot determine that for a fact.
1helpful
Had 32" luxor tv 3 years. Now when turning it on just get flashing power light. used to turn on after few blinks but not now.
you need to take it to a TV shop
or... what i do is look on EBAY for a replacement PSU panel
for the exact model number
check the PSU pcb inside the set for its part number to help match it
you give too little info for me to help further
you need make model and exact problem
its a psu issue for sure.....
some electrolytic capacitors are dried up as its aged
this is the usual cause
Top Luxor Televison & Video Experts
Paul Bade
NOEL
NOEL
Are you a Luxor Televison and Video Expert? Answer questions, earn points and help others
