Watches Logo
Peter Sarony Posted on Aug 14, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changed battery on Accurist BJ3547 as hands stopped though digital signal was still OK. New battery installed, digital signal still OK but hands still don't move . A video said a reset req'd, How?
richard mitchell
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 16, 2021
richard mitchell
Contributor
Level 1:
Answers
Questions
0
Helped
2774
Points
I realise this is an old post but its for others searching the problem as i have just done. There are two batteries one for the digital and the other for the analogue, once you've got the back off undo the six screws and lift off. There is a tiny battery under this for the analogue feature of the watch.
Level 3:
  • Accurist Master 18,429 Answers
  • Posted on Aug 15, 2016
Accurist Master
Level 3:
Answers
18429
Questions
Helped
1404564
Points
62248
  1. The "AC "or "All Clear Circuit" button if the watch has one will be found on the back of the movement. It will usually be a small silver or gold dot marked "AC" or reset. In some cases it will be a small hole or plunger you depress with a pin punch.
  2. Clear watch memory. Look for and find the small gold or silver dot on the back of the Seiko watches movement. It will be marked "AC" if it exists. Use the metal tweezers and touch the "AC" button with one prong and the battery with the other. In some cases you just push in the plunger on the "AC" button. In the case of a plunger or hole press it with a pin punch.
How do i set the anolouge hands my accurist cp00 watch
google accurist cp00 watch manual
copy and paste
https://www.manualslib.com/manual/538220/Accurist-Calibre-Cp00.html?page=2#manual
Jun 20, 2023 • The Watches
Reset chronograph hands on Accurist 7344
To reset the chronograph hands on an Accurist 7344 watch, you will need to follow these steps:
  1. Pull out the crown to the second click (time-setting position)
  2. Press and hold the top button (located at 2 o'clock) until the chronograph seconds hand returns to the 12 o'clock position.
  3. Release the button and then press and hold the bottom button (located at 4 o'clock) until the chronograph minutes hand returns to the 12 o'clock position.
  4. Release the button and push the crown back in to the normal position.
It's important to note that these steps may vary depending on the specific model of your Accurist 7344 watch. If these steps don't work, refer to the manual or contact the manufacturer for more detailed instructions. Additionally, if the chronograph hands don't move at all, check the battery and make sure it's properly inserted and the watch is working properly after replacing it, if not, contact Accurist customer service for more assistance.
Jan 14, 2023 • The Watches
How to remove back off accurist skymaster
Be sure of your model:
http://www.accurist.co.uk/customer-support/instruction-manuals/
Next things you need to know: http://www.accurist.co.uk/wp-content/uploads/2014/12/CHRONOGRAPH-2014.pdf
Most Chronograph style Accurist watches have back removed with tool: (maybe needle nose pliers would work)
assuming you are out of 2yr warranty ...
Accurist mb929b manual
The problem with the advice to visit the Accurist website is that the pdf manual they publish contains the instructions for digital settings, but NOT instructions for incrementing the analogue hands. I have emailed them about this, but meanwhile, there's no information readily available on the web for changing the analogue time on this model.
Oct 26, 2013 • Watches
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
7. Push the lower right button back in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 • Watches
Lost instructions for accurist chrono mans watch
It should have a CAL number engraved on the watch back and using this you can find instructions for download at www.accurist.co.uk under the after sales service area and downloads option.
Resetting the time
.im looking for instructions on an Accurist watch model MB008 many thanks
Jan 05, 2008 • Watches
Top Accurist Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Accurist Watch Expert? Answer questions, earn points and help others
