When I turn the quantum wheelchair on the lights just flash,the the speed .?speed gear flashes at number 2 and 4 ,no movement
The wheelchair just stop when it was in 4 gear.the control stick kept blinking,the the joy stick gear stick was flash 2. 4 there are 5 Dots in a lineit's quantum 600 thanks
The Drive Dart has a computer based controller that performs a Power On Self Test (POST) of the scooter, its wiring and components. Please count the number of flashes as this flash code tells you where to look to solve the POST problem. The manual can be found here: Drive DART Owners Manual
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Flash Code 2 indicates that the voltage is too high or too low. Check batteries and cable connections. Charge the batteries. If this fault occurs during battery charging, the charger is defective or not adjusted correctly. Empty batteries will charge. Dead batteries will not normally charge.
Could be in sleep mode try pressing the on/off button twice to get out of sleep mode if that doesn't work then you have a joystick problem and it needs to be replaced Hope this helps
Count the number of flashes this will give you an error code and you can determine the error by the number of flashes your users manual should list the error codes and their meaning. If not call Hoveround Tech support for help Hope this helps you
Cezna Are the lights that are blimking the battery level lights or they the speed level lights. If it is the speed level lights then the chair thinks you still have the charger plugged in. If it is the battery level lights do a certain number of lights flash 3 lights flashing 4 lights flashes etc this is the flash code and will tell you what problem you have. It could also mean that you are in lockout or sleep mode If you have the VSI joystick then turn on the power immediately push the joystick forward and hold until you hear a beep then mmediately push it to the rear til you hear a beep then immediately let it return to the center position. If it was in sleep mode this should wake it up. Hope this helps you
Make sure the charger is unplugged from the chair and that the chair is in gear. There's two levers that place the chair in freewheel, or neutral so you can roll it around. Place these in neutral, then back in gear firmly. If still flashing, turn chair off, wait three seconds and turn back on, then push on the horn button three times. This will take it out of sleep mode. Still not going, you will need to check all clip-on connections to make sure they are tight.
I am assuming that all of the lights are flashing constantly. If it flashes a "fault code", you will get a series of flashes from 1 to 10, then a pause, then a set of flashes. Count the number of flashes and it will tell you what the fault is for that number of flashes in the owners manual. If it is just two red lights flashing constantly, you have a set of dead batteries.
