Garden Logo
Donald Goodman Posted on Aug 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ryobi 40022 trimmer (40v lithium battery) has completely stopped working. Battery and charger kept inside when not in use. Battery indicates that it is fully charged when in the charger. Any ideas?
  • Donald Goodman
    Donald Goodman Aug 13, 2016
    Called Ryobi and they will replace the battery. However, batteries have been on back order since June so no telling when replacement battery might arrive.
Tommy Thomas
Level 3:
  • Master 430 Answers
  • Posted on Aug 13, 2016
Tommy Thomas
Master
Level 3:
Answers
430
Questions
5
Helped
127612
Points
1231
Sounds like a bad charger my friend..test suposly charged battery with a multimeter and you will find your answer...can also test charging unit with it too...GL
Testimonial: "Thanks Tommy."
Ryobi RY40002 String Trimmer motor runs slowly and rough
Question edited to add FULL make model (what it is).
Category moved from Washing Machines to Ryobi Trimmer.
Replace the spark plug. Strip and clean the carburetor. Replace the fuel with fresh. But hang on though, the RY40002 is electric and runs with a 40 volt battery, so no spark plug and carburetor! :>D Replace the battery, lubricate everything from the motor to the head. Check the motor with nothing attached to it. The carbon brushes may need replacing or its bearings need greasing.
Ryobi RY40002 40V Power Head and RY15523A Expand-It ...
https://www.walmart.com > ... > All Trimmers and Edgers
Includes (1) RY40002 40V Power Head and (1) RY15523A Expand-It Trimmer Attachment · Compatible with All Ryobi 40V Lithium-Ion Batteries (Sold Separately) ...
US$119.90 · ‎Out of stock
2answers
What are the battery possibilities for 40 volt MAX^ lithium trimmer edger 2.0 AH
Replacement Black & Decker LBX2040 Cordless Drill Battery
Type: Li-ion
Volt: 40V
Capacity: 2500mAh
Color: Black
Weight: 1250g
Dimension: 182.88 x 86.36 x 149.86mm
Please go to view more about this battery on http://www.drill-battery.com/buy.php/black+&+decker_LBX2040_drill+battery.html
May 01, 2021 • Garden
2helpful
Ryobi 40V 2.6A battery. When I put it on the charger the charger blinks green for about 10 minutes and then goes to solid green. However, after 5 minutes of use my Ryobi trimmer dies. I repeat the...
From your description the battery is probably faulty. If the batteries are still quite young it is possibly just one cell and while Ryobi don't refurbish batteries there are companies dotted around that do.
If it is a nicad battery, Ryobi told me just a couple of days ago they no longer supply nicad replacements and expect everyone to upgrade to lithium, which means also buying a charger.
Ryobi 40v trimmer stops working with 1/2 charge left on battery
Battery is weak. Those lights are really useless...more a marketing gimmick. It almost sounds like it developed a memory...this happens when certain types of batteries are not fully discharged before being placed on the charger. Replace the battery and make sure to follow charging directions for that particular type of battery
I just bought a combo 18V Ryobi blower P2102 and trimmer P2002 which also came with a charger P113 and Ryobi lithium battery. I charged the 18V lithium P104 battery 48WH till light turned solid green on...
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
13helpful
2answers
Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
3helpful
4answers
Top Ryobi Garden Experts
Jay Finke
Jay Finke
john h
Steve Sweetleaf
Steve Sweetleaf
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
