The stove top elements (except the warmer element) stopped working suddenly. Oven still worked. Flipped breaker, but still did not work. After about a month we flipped breaker again and it started working. Worked for about 3 weeks, then stopped again. Flipped breaker and got an error code F 20. Elements still not working but oven and warmer element work.
You didn't specify the brand or model, if this is a Frigidaire, the Frigidaire technical documentation states that the most likely cause is a bad Electronic Oven Control (EOC).
Try checking the wire harness and the P4 connector at the EOC. If the wire harness and the connector are fine, replace the EOC.
You have a defective breaker. Once you replace it the oven will get the correct voltage restored.
