Heating & Cooling Logo
Chris Shackelford Posted on Aug 12, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My new air portable unit is supossed to be self evaporating it is not working i have to drain it every hour
L Pfaff
Level 3:
Top Expert:
  • Master 11,573 Answers
  • Posted on Aug 12, 2016
L Pfaff
Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3585201
Points
181713
Chris, reread manual, if everything hooked correctly, return unit for refund or replacement.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Im owner of portable air conditioner acw 800 unit shut off last nite water overflow ....cleaned good this am but unit ran 1/2 hour and water all over floor would run but leaking ...:?
The unit is supposed to be self draining and it does this by using the condenser coils to raise the temp of the condensate that drains off the evaporator coils. Unfortunately there is a limit to how much moisture it can deal with and high humidity can cause the water to overflow into other areas of the base. They are also not user friendly to disassemble and clean.
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Dripping water from portable aie condtioner
Remove the rear cover and clean the unit throroughly. Use a can of air duster with the little hose to carefully clean the drain holes in the drip tray under the evaporator (upper radiator) let the unit fully defrost, drain the unit from the bottom plug. Clean the fins wth a toothbrush and windex if needed. Reassemble and run the unit in fan mode for an hour to let it dry out.
After years of perfect operation the water reservoir tank needs to be emptied every few hours. Is is almost a gallon of water each time. The normal time was always every other day ...at most once a...
12k BTUs will condense a gallon an hour easily, sounds like the problem is with a probable self-evaporating portion of the condenser. If so either the inner workings of that unit are dirty/malfunctioning or the exhaust duct is not getting proper airflow. If you're mechanically inclined I'd recommend pulling the unit apart and cleaning the condenser parts. If not perhaps try attaching a permanent drain hose to the drain plug. Definitely check the exhaust duct either way.
There is no drain pipe for the unit I have. It has a cap on the back but no hold, how does the condensation.
Self Evaporating Technology - During the cooling process, water is extracted from the air into the unit. Most of this water is then recycled and used to cool the unit and make it run more efficiently. Approximately 65 to 70% of water condensed is evaporated out with the exhaust air, reducing the hassle of emptying the water tank constantly. This unit has a built-in water tank (not removable) with a drain outlet, and a water tube. When the tank fills, the compressor stops operating and the power light will flash. This indicates that the tank should be emptied.
I have an amana self evaporating portable ac for my 500sf condo. I have had to unhook it and roll it outside 4 times to drain it. Lately water is now spilling out the back vent on to my floor. What's the...
It appears to me that because of the small size of your condo, you are just recirculating the humidity in the apartment. The unit is condensing the moisture in the air and then reheating it in the pan causing it to evaporate back into the air. The unit is working properly but the humidity level in your apartment continues to rise. You really need to add a drain from the pan of your portable air conditioner.
1helpful
Do i have to drain out the water is this not a self evaporating unit ?
You have to connect the drain hose to any outdoor location . If it is a plate type condensor it is self evaporating. Or if the drain pan is on top of the compressor then you have to drain it out now and then.
This is a stand alone portable 10,000 sharp portable AC
I had the same issue of filling up after a couple hours but mine started making some pretty loud noises as well just before shutting itself down and lighting all three lights. The top drain valve would no longer work and the only way I could drain it was through the bottom (gravity) drain valve. I took the unit apart and found that the simple water pump that is used for draining and the evaporating process had lost the thin filter screen on the bottom and the screen became lodged in the impeller of the pump preventing it from spinning. I removed the worn and broken plastic screen, carefully pushed the impeller back up on the shaft until it bottomed out, and cleaned all the built up sediment off the entire pump. After reassembling everything, the ac unit runs like new again and the noise is completely gone. Cost? $0
I imagine you can just order a new pump from sharp and save the time and effort of cleaning the pump.
Hope this helps!
Amcor ALD12000E portable air conditioner shuts down every hour
Is it leaking or shutting off on the overfill?
If it is leaking you have a stopped up drain inside the unit.
jim
Bought Amana 7000 BTU portable air conditioner for my father and he is telling me that it's leaking all over. I thought it was a self absorbtion.
Self absorbtion means that the water is evaporated by the blower blowing air over the condensation. On very humid days there may be too much water to evaporate. There should be a drain outlet on the back and it may be blocked. Clean it if you can find it.
Top NewAir Heating & Cooling Experts
Paul Carew
john h
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
