Apple iPad 2 Logo
C
Charles Hatcher Posted on Aug 12, 2016
My lumosity app quit woking
All other apps wok fine
I'm using an apple iPad, when I go on Facebook marketplace, I save certain items. Then later when I try to access the things I had on "saved" all is it that I'm getting is a blank screen.
If you are using an Apple iPad and are having trouble accessing your saved items on Facebook Marketplace, there are a few things you can try to troubleshoot the problem:
  1. Clear cache and cookies: Clearing the cache and cookies on your iPad can often resolve issues with apps like Facebook. To do this, go to the Settings app on your iPad, then select Safari. Scroll down to the "Clear History and Website Data" option, and select it. Confirm that you want to clear the data, then try accessing your saved items again.
  2. Update the Facebook app: Make sure you are using the latest version of the Facebook app. Open the App Store on your iPad and check for any available updates. If an update is available, download and install it.
  3. Restart the app: Try force-quitting the Facebook app, then reopen it. To do this, swipe up from the bottom of the screen and pause in the middle of the screen to see the app switcher. Swipe left or right to find the Facebook app, then swipe it up to quit. Open the app again and see if the saved items are now visible.
  4. Contact Facebook support: If none of the above solutions work, you can try contacting Facebook support directly. You can usually find a "Help Center" or "Support" section on their website, which may have resources for troubleshooting specific issues.
Remember, if you are unable to access your saved items on Facebook Marketplace, you can also try bookmarking the pages of individual items you are interested in to access them later.
Howdo you get the sd card to accept apps?
Most apps will not use the SD card. Whether or not this will ever change, I cannot tell. It makes device quite limited on what it can do. Some apps will store cache and data on the SD card, but you need to go through the App Management function to find them.. If they are able to use the SD card, those app will have the option for moving the app/data to the card highlighted. Otherwise it will be greyed out.
I have been using the app magic puzzles for a while. it now doesn't open. I have rebooted the ipad and updated the ipad and still doesn't open. what can I do?
First, quit all running Apps by double clicking the home button. Then swipe each one upward to remove from memory.
You have a 16gb iPad which I would not own because it is very limited with its memory. Minimum for App users should be 32 or 64gb.
Once all Apps are out of memory then hold top on off button in for about 10-15 Seconds until iPad shows Apple logo. It's Restarting.
Try your App again.....
If this fails to fix the problem then dump the App and Re download from the App Store. You own it so it won't cost anything if your using the same Apple Username & ID.
Just hold down on the App until it wiggles then click the x in the corner of the icon.
Go to App Store & find App and re download.
Hopefully this should fix the problem.
On a 16gb iPad it would be wise to not allow to many Apps to stay in Memory. Just double click the home button once in a while to clean up
Good Luck
How do I delete a free quite time application on my kindle??
go into settings where you will find Manage Application then scroll down to what you wish to remove the app will open just click on uninstall , or you can go to play store type in the app you wish to remove when app opens it should say uninstall then click on it.
1helpful
2answers
Hasn't saved anything to the memory card because his tablet won't allow him to .. It keeps saying not enough space it's a 8GB memory card
The internal memory cards of some Android devices are partitioned for app storage and installation. Some of them have partitions that are quite small such as one Gigabyte or smaller. The remainder of the storage cannot be used for apps.
If it keeps saying not enough memory space then chances are the app partition is full. The only way to free up some space is to uninstall some apps that are stored there but not being used. You can see which apps can be uninstalled in Settings > Apps and look at them one by one to see if an uninstall option is listed. Simply click *uninstall* to remove them from the app storage partition. This will free up some extra space for some new apps or for updates to older apps you still like and use.
Also some of the apps might show an option to move them to an external SD card (if your device has a slot for one and if an SD card in inserted therein). Do move any and all to the external SD card of you have that option as that will also free up that space from the internal SD card.
1helpful
2answers
How do I use my SD card for internal storage?
There are a quite a few options.
  1. Open Terminal Emulator and check with the 'df' command, how much space is left on your partitions. Is /data or /system full?
  2. Goto system/apps/all > 'Sort by size to' find out which apps eat
    up the most space.
  3. Check if you have big size apps installed where you could change data location within the app to sdcard. Thinking of navigation apps and games. Every app where you have to download additional data to the actual app.
  4. Make sure you use the sdcard for media like photos (camera settings) music and video.
  5. CM has a built-in system to move apps to SD under settings/apps/on sdcard. Check apps that are big and you use rarely and are not interactive first. Reason: If you still use the USB feature those moved apps are not available to system anymore and are least likely to cause trouble.
  6. Another option is to use the app Foldermount. Use it to move certain locations to SD like the Download folder. Or the DCIM folder if the camera doesn't support sdcard location in settings.
  7. Use the app Link2SD which is able to move every bit from an app (including app data) to SD. It has a good overview on how much space an app really needs. You will have to create a separate partition on the SD card for that to work.
Zynga poker app is on a zoom in large form I can not make the app small so I can play can you help tried everything
Hmm, best thing I can say is double tap the home button to bring up the open apps on your iPad. Then close the instance of the app (and any other apps) by swiping the screen images upwards. That should force the app to 'reboot' and may fix your problem.
1helpful
3answers
My Facebook app keeps crashing, it will come on but goes out in secs.
Assuming this app is on an iOS device (Apple). Following these Several steps should resolve your issue, firstly quit the app entirely by using four fingers swipe up on the tablet, or press the home button twice, either step will show the active apps, find the Facebook app, then with a single finger swipe up, this step should see the app move upwards on the screen, quitting the app. Theis next step requires you to hold the power button and the home button at the same time, until the device shutsdown and the logo appears, then let go of both buttons allowing the device to start/boot completely. Locate your Facebook app, start it, does the problem still exist? If after the above steps you still have the same issue, you can delete the app, by placing your finger over the app & holding until the app jiggles and shows an "x" in the top left corner of the app graphic, touching the "x" will remove the app from your device, you can then re-install the app, finally you may simply need to check to see if the app needs to be updated, by opening the AppStore, and selecting Updates, if an update for Facebook is available for you it will show up here. I hope something within the information has helped.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
