HP DeskJet 1220c InkJet Printer Logo
regina Posted on Aug 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My printer 1220c power button when turned on, it refuses to turn off and it displays usb not regnoised
Marvin
Level 3:
Top Expert:
  • HP Master 85,242 Answers
  • Posted on Aug 11, 2016
Marvin
HP Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29053431
Points
266281
You have a defective printer or the software in your PC is corrupted, reload the printer software, unplug the printer for 5 minutes and see if it works, if not just replace it, the cost to repair can be more than a new printer.
3 Related Answers
A
Anonymous
  • Posted on Apr 09, 2008
SOURCE: hp 1220c A3 printer not working
Make sure the back covre is securely locked. Printer will not function unless this is completely secured.
Anonymous
  • 1124 Answers
  • Posted on Sep 24, 2008
SOURCE: Black lines in display and printer will not turn off with on/off button
If your printer does not function properly, or communication error messages appear when using your printer, you can remove and reinstall the printer software.
  1. Click Start®Programs or All Programs®Dell Printers®Dell AIO Printer 946.
  2. Select Uninstall Dell AIO Printer 946.
  3. Follow the instructions on the computer screen.
  4. Restart your computer.
  5. Insert the Drivers and Utilities CD, and then follow the instructions on the screen.
If the installation screen does not appear:
    1. In Windows XP, click Start®My Computer.
In Windows 2000, double-click My Computer from your desktop.
    1. Double-click the CD-ROM drive icon, and then double-click setup.exe.
    2. When the printer software installation screen appears, click Personal Installation or Network Installation.
    3. Follow the instructions on your screen to complete the installation.
      If the problem continues, the printer needs to be serviced.
Anonymous
  • 47 Answers
  • Posted on Oct 17, 2010
SOURCE: I have an a hp 1220c, When I plug it in and press
try removing the power cable then keep the power button pressed while the power button is pressed plug the cable back and don't release the button for 5 seconds
then try
Hp dj 1220c printer driver refused to install on my windows 7
Try to reset the factory settings: Go to Settings tab and press the Resets option. This will change all the settings to default factory settings. Try to print using another OS and check if there is a difference in the print quality. Try to print in draft mode and in FastRes 1200 mode. Tip and tricks for all deskjet setup
https://123hp.co/hp-deskjet-printer-models
How to fix B200 E30 error for mp198
A. Entering into service mode
  • Turn off the printer off is the printer power on. And remove the printer USB cable from your computer..
  • While the printer is OFF, press and hold the Start/Stop button on the some other canon printers model press Resume/Cancel button.
  • While still holding Start/Stop button or Resume/Cancel button, press and hold the POWER button.
  • When the POWER LED (green light) lit, release the Start/Stop or resume/cancel button (still holding the POWER button).
  • Still holding the power button, Press the Start/Stop button or resume/cancel button TWICE then Release the POWER button. Wait until LCD printer to display 0 (zero) number
  • After the display is 0, attach the printer UDB cable to your computer, its will detected new device installed (its normal), now go to resetting steps
B. Resetting Ink counter on the Printer
Run "service_tool 1050.exe". you can download the service tool software from this link:
http://www.ziddu.com/download/10241255/ServiceTool_1050.zip.html
  • Confirm detected USB-port numbers on USB port column.
  • Click "Main button" on Clear ink counter section. Make sure there are papers in the paper feed because the printer will print after the process is complete.
  • Click "platen button" on the "Clear ink counter" section. The printer will print again.
  • Turn off the printer and then turn the printer on. You printer is ready for use.
12helpful
My canon mx320 multi function printer doesnt want to scan. it shows a U051 code and refuses to work.does a printer need tp have ink to scan?? i dont think so. pl help
Need to reset the cartridge.
How to fix the printing problem when Canon PIXMA MX320 series detected the errors in your cartridge?
After refilling the cartridge, the next thing to do is to reset the cartridge. This will clear your printer from displaying common printer errors like U041, U042, U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
For error U162 or U163 All functions of the all-in-one printer will stop and your printer will not work.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
Please give this solution a good ratings. thanks
I have an a hp 1220c, When I plug it in and press the power button, the green light comes on for a second and then it turns off. the printer will not start up.
then try
109helpful
6answers
1220c driver for windows 7
HP 1220c driver for Win 7 is nit working, need help
I have a HP Photosmart 8250 printer. The printer is reporting an error code 0xc18a030a and it is saying INK FAILURE. Then it refuses to print. Any help at all would be soo greatly appreciated! HELP!. I am...
Reset the product:
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
4helpful
Printer cycles on/off and displays "improper shut down"
Got the same problem following a message "Printer ink failure" code 0xc19a0035. Instructions say to shut down using button on/off. But printer refused to shutdown. After 30 minutes, I disconnected power cable. Removed cartridges. Reloaded cartridges. Reconnected power cable and got "Improper shutdown" message with continuous cycle. Solution: 1. While the printer is still turned on, unplug all cables and cords at the back of the printer.
2. Unplug the power cord also from the wall outlet...
3. Wait for two minutes.
4. Reconnect power cord to the wall outlet first.
5. Press and hold the pound (#) and six (6) buttons.
6. While holding down the two buttons, reconnect the power cord to the back of the printer and after two seconds, release pound and six buttons.
7. Turn on the printer if it turns off... and it's fixed.
HP Deskjet 1220c won't print
This is a problem with the carriage. Unplug the printer from the wall and the computer wait half an hour and then plug it back in and see if you have the same problem please post the results.
2answers
Hp 1220c A3 printer not working
Had the same problem, some where there is a fix on the web, changing out a 1/2 watt resistor fixes it!
k24674
Grand Canyon Tech
Grand Canyon Tech
