Televison & Video Logo
G
Gerry Hogan Posted on Aug 11, 2016
Im looking to purchase a remote control for my Sigma as227 led moving sign can anyone help.
Has anyone got details of where i could purchase a new or secondhand remote control for the Sigma as227 moving sign.
PANOS KRIPASIS
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 18, 2019
PANOS KRIPASIS
Contributor
Level 1:
Answers
Questions
0
Helped
217
Points
Just look www.megatrustshop.com we have by the way price 12 euros
5 Related Answers
Anonymous
  • Posted on Feb 17, 2008
SOURCE: DS 27930 remote control
My problem is this TV of ours does not work now so if I cannot get it fixed I guess you can buy our remote control.
Doopey
Adrienne Haswell
  • Posted on Jul 15, 2008
SOURCE: I require to purchase secondhand
Managed to get one locally and glued mine until it arrives
Adie
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on May 24, 2010
SOURCE: im looking for a new remote control for my wega tv...
you can get them from www.tvrepairworld.com
Anonymous
  • 1456 Answers
  • Posted on Jan 30, 2011
SOURCE: I have a bonaire VSM65
Hello
Check the Room Thermostat Temperature Setting: Set the thermostat to at least 5 degrees below room temperature.
Check that the Room Thermostat is set to "Cool" not "Off" or "Heat". If the thermostat is not set to "cool" it is simply turning off your A/C.
Check that electricity is on for the equipment. Check all switches and controls, including service switches, including outside by the compressor, inside at the air handler, and fuses or circuit breakers in the electrical panel.
For example, condensate spilling into an overflow pan that uses a sensor switch can be enough to shut down your air conditioner. There are several switches and controls, both manual and automatic that can leave an air conditioner or heat pump turned "off" such as a blower compartment door interlock safety switch, an electric motor overload or overheat switches, and a condensate tray spillage detector switch.
Go to AC HEAT PUMP CONTROL AND SWITCHES to be sure you have found and checked every manual or automatic electrical switch on the system. A bad or failed starter capacitor could also be leaving your system shut down, failing to start a blower, fan, or compressor motor.
If the air conditioning system is still not working, or if the A/C system is running but cool air is not coming out of the supply registers you probably need to call a service technician.
THANK YOU FOR VISITING FIXYA
gopakumarg43
  • 76851 Answers
  • Posted on Aug 10, 2012
SOURCE: I lost my RC-6AR03 remote when moving,can I get a replacement.
Check this link to get mode details about its availability.
Im looking for a Thomson remote urc60230roo-oo 3rc16-1124 can anyone help
If you wish to buy it's original remote control, just contact the authorized service center for Thomson.
To select a universal remote control, make sure about the set up codes for t Thomson, and buy a remote control of that brand, from open electronics spare part market. Refer the sites linked here for more details about the codes.
http://elecrtohelponline.blogspot.com/
http://remotesearch.blogspot.com/
http://homenol.blogspot.com/
I need got code of the remote control model sigma kt-3888 universal a\c
Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given.
2908,2984,2954,2917,2957.
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Im miss my remote. ... where purchase
Remote controls can be purchased from most of the electronic spare part selling shops. But, before purchasing a new one, you must make sure, that the remote control you're going purchase have setup codes to your device brand. To get more details about this, check the sites linked here. It has setup code list, and setup procedure to most popular remote controls. Refer it, cind the details, and buy a remote control according to availability.
I NEED THE CODE TO MY SAMSUNG REMOTE 00052A, I'VE ONE DVD-HR775A/XEE THE REMOTE FOLLOWED WHEN I BOUGTH IT NOT LONG AGO BUT I HAVE BEEN MOVING IN THE MEANTIME SO IT HASN'T BEEN IN USE FOR SEVER
The remote control should be checked for its infrared emission. If you wish to get more details, visit this site. Pull up older posts there. One among it has detail description about how to check and repair or clean a remote control. Check the site with patience. I'm sure that you will get all details you wants to know.
IFlashing F--
are you using this on a nikon camera if so the iris ring may have moved you need to move the ring to the red number you will see a bump on the iris ring there is a swich you slide to see a orange dot this will lock the iris ring
My video card is Sigma Geforce mx 440 and i dont have a driver. im having problem when im playing. pls help me find this driver so i can download it for FREE!..
REMOTE SEEMS TO HAVE DIED - RED LED VS GREEN
There is a very strong chance that something foreign has gotten into the touch membrane for your remote control or the link from the touch pad to the circuit board. If it is still under warranty, get it replaced. If it is not under warranty a new universal remote may be on your next shopping list. Repairs to OEM remote controls cost more than a new one.
Hope this helps...
I just can't get it to work, new batteries and all.
First check if the remote control is sending an infrared signal. If the LED is flashing, this does not mean the Remote control is sending the IR signal. There is a separet Infrared LEd that sends the signal. To check the IR, point the remote control in a video camera or any camera with real-time monitor (phone cam, webcam, etc.) and press any button. You will see a white flash coming from the Remote control. thjis works best if the camera is black&white, for color camera, the IR is still visible but quite faint. Another way of checking the IR (if you do not have a camera) is to press the RM in front of another device with remote control and while doing so, press the correct remote control . If that other does not function or functions erratically, then the remote control in question is emitting an IR signal. If there is no IR coming out, the solder conection of the IR LED might be the problem. It is rare that the IR LED will be damage because the remote control is only 3 volts. If the remote control does emit an IR signal, then the TV remote reciever is defective. I had this problem with a CD player that I have fixed. The IR reciever looks like an LED (dark colored) with three pins (V+, signal, ground). Cost less than $3
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
