Toro Power Lawn Mower Logo
T
Tony parrish Posted on Aug 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gov and throttle linkage
Where does the rods and spring hook up to
Jim flowers
Level 3:
  • Toro Master 1,098 Answers
  • Posted on Aug 10, 2016
Jim flowers
Toro Master
Level 3:
Answers
1098
Questions
Helped
359200
Points
2966
Gov. rod hooks to the hole in the top of the butterfly. the spring hooks to the carb and the front of the engine on the metal tab.
Where does the gov rod and throttle rod hook on a 6.5 hp lev120 on a toro recycler 22 lawn mower
gov. rod goes to the hole in the carb. spring goes to the metal tab on front of engine
Aug 10, 2016 • Toro Garden
How to hook up kick down linkage on 1965 ford v/8 automatic?
Well there's a kick down rod or linkage that runs from the carb linkage to the kick down arm on the trans. Once that is on there should be a little spring that holds the weight of the linkage off of the kick down arm on the trans. That spring is at the carb end. Once you have it hooked up you can drive it and adjust to desired kick down feel.
The Throttle linkage on the carburetor came off where does it go
on the inner butterfly linkage on the carburetor closest to the engine
Adjusting governor/throttle briggs and stratton
there should be a little screw to help adjust your idle try that..counterclockwise to add more idle, clockwise to slow idle..
TOOK CARB OFF TO CLEAN OUT "GUM" FROM SITTING. DURING RE-ASSEMBLT SOLID 1/16" ROD FROM GOVERNOR ARM TO THROTTLE PLATE ARM HOOKED UP OK. THEN I DISCOVERED A VERY LIGHT WEIGHT SPRING AROUND...
the little spring should go through same holes as the linkage it's purpose is to take the slack out of the rod to keep the engine running smooth a broken spring will cause it too run erratically
What connects the throttle linkage to the carburator? is it a spring or rod
It's actually a combination of both. There should be a small rod at one side of a small plate, (which acts like a cam) and a spring on the other side. The throttle cable pulls the plate and rod, expanding the spring at the same time. When the cable is relaxed the springs pulls the linkage back.
Mar 16, 2010 • Pool & Spa
3helpful
Governor and Carb spring linkage
the solid wire link goes from the top hole in the governor rod to the carb and the spring goes from the lower hole on the rod to the throttle plate where the cable attaches
Carb and throttle linkage on a Tecumsen LEV120 361015A
You want the spring to hold tension against the governor.
May 17, 2009 • Garden
Top Toro Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Toro Garden Expert? Answer questions, earn points and help others
